Suspension 18" with H&R springs
Old Apr 13, 2011 | 12:36 PM
erdalozan's Avatar
erdalozan
I want to install H&R springs and wanted to know if that 1.4" drop will cause issues as i have 18" wheels.
Any suggestions? I am going with H&R as my service guys is telling me that everything will be covered under warranty if i have any problems with springs and he has not heard NM before...
Old Apr 13, 2011 | 12:39 PM
ThumperMCS's Avatar
ThumperMCS
I'm on Mach V springs and 18's....215/35/18, no rubbing at all.. Not even close, you'll be fine
Old Apr 13, 2011 | 02:12 PM
iwashmycar's Avatar
iwashmycar
should be just fine. the total outside wheel diameter doesn't really change any.
Old Apr 14, 2011 | 08:33 PM
erdalozan's Avatar
erdalozan
ok i am installing them tomorrow... pics will follow...
Old Apr 15, 2011 | 04:50 AM
Stryker305's Avatar
Stryker305
You only have problems like rubbing when you add spacers 15mm or 20 mm
Those will rub also if one does go with spacers that size, there is a sharp edge to the wheel well inside the plastic wheel arch which is metal and will cut into the tire, talking from experience.
Old Apr 16, 2011 | 07:09 AM
erdalozan's Avatar
erdalozan
i heard some rubbing the first time i drove it when i was making a left turn. I drive an hour and now i dont hear it. Went to the same place it rubbed but nothing. I will go to the shop today so they can double check everything. I really do not want any rubbing at all.
Car dropped and looks awesome though... Now it really feels like i have a different body kit than regular mcs.
Old Apr 16, 2011 | 07:18 AM
teamrubixcube's Avatar
teamrubixcube
Pics please!
Old Apr 16, 2011 | 11:52 PM
drhubie's Avatar
drhubie
H&R Springs and 18" Wheels
I have the same setup and no problems...you will notice a "firmer" ride
Old Apr 17, 2011 | 02:00 PM
automan21's Avatar
automan21
The rubbing you heard was probably the tire rubbing against the plastic splash guard in the wheel well. It rubbed enough away that you dont hear it now.
Old Apr 18, 2011 | 10:17 AM
erdalozan's Avatar
erdalozan
you are right! no sound for the last 2 days. Mini is handling it like crazy. Happy with the setup.
Here are some pics.
Old Apr 18, 2011 | 03:16 PM
automan21's Avatar
automan21
Looks nice, when you painting the wheel arches?
Old Apr 18, 2011 | 03:18 PM
automan21's Avatar
automan21
Hey your headlight rings and grill are they plasti-dipped?
Old Apr 18, 2011 | 05:05 PM
drewstermalloy's Avatar
drewstermalloy
The drop looks really good! My h&r springs aren't that even.
Those unpainted arches drive me nuts!
Old Apr 18, 2011 | 05:26 PM
erdalozan's Avatar
erdalozan
not thinking about painting the arches as i might get the jcw kit.
It is not plastidip, it is painted to flat black.
Old Jul 11, 2011 | 12:54 AM
MiniBOL's Avatar
MiniBOL
Looking nice Erdalozan!
I put 5mm H&R spacers but I'm thinking I may want to change them to 10mm. I have 215/35/18 with NM springs on the car now. Do you think I will have rubbing with 10mm?
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
CooperSharp
Oct 12, 2015 09:21 AM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
nshannon29
Sep 30, 2015 05:21 PM
