Suspension Ireland Engineering fixed camber plates gone bad
Old Apr 11, 2011 | 06:46 PM
drftobin's Avatar
drftobin
I think I blew out one of the bearing on my Ireland fixed plates getting that all to familiar strut bearing clunking. anyone know if you can replace just the bearing on the plate?
Old Apr 12, 2011 | 03:16 AM
HRM's Avatar
HRM
I think it is a replaceable bearing. Way would know.
Old Apr 12, 2011 | 07:32 AM
quikmni's Avatar
quikmni
The bearing on my H-Sport camber plate started to clunk and I was able to clean and relube the bearing, while still mounted in the plate, to resolve the clunk without having to replace the bearing. I did remove the camber plate from the strut so I could move the bearing in all directions during the cleaning and lubing. The bearing was just frozen a little (did not move well) and that caused the clunk.
Old Apr 12, 2011 | 08:03 AM
00zero's Avatar
00zero
i seem to remember someone saying the bearing is actually off of a z4 but i may be wrong. Give Ireland or way a call. -Jonathan
Old Apr 12, 2011 | 01:43 PM
drftobin's Avatar
drftobin
If it is a Z4 mount that would be good easy fix
Old Apr 13, 2011 | 04:03 AM
drftobin's Avatar
drftobin
Anyone know what year z4 the mounts are from?
Old Apr 13, 2011 | 04:04 AM
drftobin's Avatar
drftobin
y
Old Apr 13, 2011 | 01:15 PM
HRM's Avatar
HRM
Why don't you just ask them....
http://www.iemotorsport.com/contact.html
Old Apr 13, 2011 | 01:54 PM
drftobin's Avatar
drftobin
Contacted way already no word back yet
Old Apr 13, 2011 | 04:21 PM
HRM's Avatar
HRM
I just spoke with Lee at IE.
They take stock plates and modify them to fit on/in the adapter. Just get a stock or OEM bearing, take the IE apart, and with a griding wheel or bandsaw duplicate the trimming and bolt it in.
Any more questions just call him. *see link above
Old Apr 13, 2011 | 05:57 PM
Vollgas's Avatar
Vollgas
I don't hear anybody mention what they are using for lubeing the bearings.
Helix recommends using Anti Sieze compound.
Have used it on all sorts of things.
Really works.
Old Apr 14, 2011 | 01:22 PM
drftobin's Avatar
drftobin
Thanks HRM, did he mention what year Z4
Old Apr 14, 2011 | 03:16 PM
HRM's Avatar
HRM
They are stock mini bearings according to Lee.
Old Apr 15, 2011 | 05:06 AM
drftobin's Avatar
drftobin
not unless they are from a newer 07 up ?
Old Apr 15, 2011 | 04:39 PM
drftobin's Avatar
drftobin
Pulled my front right strut today at work to check the bearing, its bad and it is a bearing from a Z4 with the studs and tab drilled and a piece chopped off the edge going to pic some new ones up tomorrow
Old Apr 26, 2011 | 06:05 AM
Cole9953's Avatar
Cole9953
Do I carry this washer over to the new plates?
Old Apr 26, 2011 | 08:11 AM
Vollgas's Avatar
Vollgas
Yes.
Make sure bearings are packed.
Old Sep 24, 2011 | 09:57 AM
Cooper_Climax's Avatar
Cooper_Climax
I haven't contacted Ireland Engineering yet... but do you have any radial cracking in that 'rubber like' BMW bushing? Mine started cracking after 15 months and now at 27 months looks like they may fail.
Old Sep 24, 2011 | 07:38 PM
donjulio's Avatar
donjulio
my ie fixed plate's rubber is ripped as well
Old Oct 9, 2011 | 09:49 AM
Cooper_Climax
I have been out of town for a couple weeks but now I'm getting back to my bearing-bushing radial cracks problem. I think these are BMW Z4 pieces that Ireland Engineering attaches to their fixed camber plate product.
In my case the IE fixed camber plates bearing-bushing had some cracks at 15 months with only 5366 miles. 68 of those miles were on a paved road course circuit, race track. I'm at 27 months and 9873 miles (total of 90 track miles) and they have severe radial cracks or tears. I'm using DOT tires and not run flats.
Anyone else having this problem besides 'donjulio'?
I am sending this to Ireland Engineering to see what they suggest.
The first photograph is of the right front strut top bearing-bushing with radial cracks or tears. Second photograph is the left front with bearing dust cap removed.
11 October 2011 Update. Jeff, Ireland Engineering, agreed that the condition of these upper strut bearings is abnormal and he is helping me get this corrected. I bought the product from Dustin at AutoXCooper and he has been very supportive as well. A big thanks to Jeff and Dustin.
Attached Thumbnails Ireland Engineering fixed camber plates gone bad-strut_bushing_radial_cracks_9873-miles_rf.jpg   Ireland Engineering fixed camber plates gone bad-strut_bushing_radial_cracks_9873_miles_lf_close.jpg
Last edited by Cooper_Climax; Oct 11, 2011 at 06:06 PM. Reason: Update after consulting vendors
Old Feb 14, 2013 | 12:48 AM
Cadenza's Avatar
Cadenza
Torn strut mount...
hey gang -
My '06 MCSc has 44k with original issued strut mounts, which I've always keep an eye on. After a recent 1000 mile trip, I discovered that the front right (passenger side) strut mount has a tear of ~1 inch... straight line from center outward.
With what seems like premature wear on the Ireland Engineering fixed plates, I was wondering if it was isolated. Besides the thicker plate, is the rubber mount any better than OEM???
Thanks!
PS: what is it with BMW/Mini bushings and strut mounts that last only 1/4 to 1/3 the time of other manufacturers?
Old Feb 16, 2013 | 11:35 AM
ashchuckton's Avatar
ashchuckton
I have about 85,000 miles on my IE fixed plates. All is well with mine.
Old Feb 19, 2013 | 08:13 PM
hunter99's Avatar
hunter99
40k on mine and no issues at all.
Old Feb 22, 2013 | 02:53 AM
lizandrooo's Avatar
lizandrooo
I have my IE fixed camber plates and all is dandy except for one thing. I had bought the Craven strut tower defenders and when I was installing the larger lug adapters to the skinny strut tower mounts from the IE Camber Plate, I over torqued the lug and ended up poping off a stem from the IE Camber plate!!!!! Anyone know if this is an easy fix & what size stem I should get ? I get the impression that it could turn into an easy home depot fix from the looks of it but not 100% sure. Anyone ?
Old Feb 22, 2013 | 10:58 AM
Cooper_Climax
I recommend you contact IE and see if they send you a new stud bolt. The fastner isn't designed for a high tensile force. I believe the torque value with a new nut is only 25 lb-ft.
