R50/53 Going to do normal maintenance. What to do?
Old Apr 9, 2011 | 07:38 AM
Fatandre's Avatar
Fatandre
Hi guys. I am about to do normal maintenance on the car. I have only been driving it and from when I bought it it had no history. Have had no problems with it so far.
Just when I am standing and the car is running it gets sometimes this rough idle.
Let the info flow
Old Apr 9, 2011 | 08:17 AM
Vollgas's Avatar
Vollgas
What year of car?
If a 1st Gen car, 02-06, I would buy the Bentley Service Manual before I do anything.
It will help with any maintence issue that you want to do.
It has dirty pictures.
Old Apr 9, 2011 | 08:47 AM
wrh3's Avatar
wrh3
Old Apr 9, 2011 | 08:59 AM
Fatandre's Avatar
Fatandre
Its a 2005 R53 first gen
Old Apr 9, 2011 | 06:15 PM
Evasive's Avatar
Evasive
Miles would help. Few things I wool look into...
Oil change
Coolant flush
Spark plugs
If high miles, new ignition cables
Fuel filter
Intake filter cabin filter
Inspect bushings
Transmission fluid
Inspect brakes
Check for any leaks
Old Apr 9, 2011 | 06:27 PM
Fatandre's Avatar
Fatandre
The car is driven 75k km its about 40 k miles
Old Apr 10, 2011 | 01:20 PM
Fatandre's Avatar
Fatandre
anyone?
Old Apr 10, 2011 | 03:50 PM
wrh3's Avatar
wrh3
As mentioned above, I would change ALL fluids:
Engine Oil/filter
Transmission Fluid
Brake Fluid
Coolant
Maybe PSP fluid?
Check wear items:
Brake pads/rotors
Motor mounts
Front lower control arm bushings
Check for oil leaks:
Oil pan gasket
Crank Sensor o-ring seal
Oil cooler
Crank seal
Check plugs/wires/coil terminals
Check coolant reservoir for signs of leaks
Check PSP fan: does it free spin or feel gritty? It can be removed and the dirt shaken out. Also check operation by turning the AC on and make sure it turns on.
I spent an hour under my car and then under the hood with a shop light and flash light checking everything out and getting to know my new car, the forums are very useful and a lot of DIYers have assembled good info for us late bloomers
Colt45Magnus
Aug 27, 2024 05:03 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
hockeydad51
Oct 9, 2015 01:51 PM
navybsn
Oct 4, 2015 03:27 PM
Miniwaukee
Sep 29, 2015 09:22 AM
