Suspension Changing Springs
Old Apr 8, 2011 | 08:53 AM
RonMaf's Avatar
RonMaf
Changing Springs
When changing the “springs only” on the Mini do you NEED to remove the whole strut, or can I move the strut assembly down enough to take the spring off while the strut is still attached to the car?
Thanks!
Old Apr 8, 2011 | 09:00 AM
Greg Davis's Avatar
Greg Davis
You will have to remove the entire strut. It's not that bad at all though.
Old Apr 8, 2011 | 09:32 AM
countryboyshane's Avatar
countryboyshane
Bring a friend. This is a two man job unless you have a really nice spring compressor.
Old Apr 8, 2011 | 10:30 AM
slinger688's Avatar
slinger688
Fronts can be a little struggle but the rears are easy. Best to compress the front a little with spring compressors.
Old Apr 8, 2011 | 12:14 PM
RonMaf's Avatar
RonMaf
Thanks all, I do have a spring compressor, and an impact wrench, but I don't want to have any issues. My big fear is the nut that holds the spring to the strut. Is this a pain to remove? I see that people with impact wrenches have it easier.
Any recommendations?
Thanks!
Old Apr 8, 2011 | 07:06 PM
RonMaf's Avatar
RonMaf
OK so Air tools are priceless for this job!
I came home this evening with the mindset to attempt one of the front struts, and It started off with no issues, although a lot of work to do, (a helper really makes things little easier) the hardest part was the spring compression, but over all it isnt that bad. I should have this done by noon tomorrow.
Does anybody know any reputable alignment shops here in Middle TN around Franklin?
Thanks Again
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
surfblue
Oct 24, 2018 01:20 AM
melscoop
Mar 30, 2016 06:56 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
