Re:help with Ipod
Old Mar 24, 2011 | 07:12 PM
pistolpepe33's Avatar
pistolpepe33
Angry Re:help with Ipod
Ok here goes...I have Ipod hooked up to mini-connect . When I click and choose an artist and go to "all tracks" once I pick a chosen song it doesn't continue to next song automatically . I have to go back and go into tracks and choose another song. In other words it doesn't go from song 1 to song 2 etc. Please inform. Thanks
Old Mar 27, 2011 | 12:08 PM
chaos_'s Avatar
chaos_
Hummmm?
I will look into this issue... mini connected is designed to push through the iphone. I have yet to hook up any ipod, but will. and will figure this out for you... that is unless you have already solved. I have had zero issues w/ iphone.
Old Mar 27, 2011 | 12:15 PM
chaos_'s Avatar
chaos_
correction... designed to run using the App.... ipod touch, i suspect would react the same.
Old Mar 27, 2011 | 12:27 PM
pistolpepe33
thanks....nope problem still exists
Old Mar 27, 2011 | 12:32 PM
chaos_'s Avatar
chaos_
what ipod are you pushing through?
Old Mar 27, 2011 | 04:41 PM
pistolpepe33
ipod classic
Old Mar 28, 2011 | 10:01 AM
chaos_'s Avatar
chaos_
oool, i have just about all versions. I will try using the classic.
Old Mar 28, 2011 | 12:50 PM
punkrockdoc's Avatar
punkrockdoc
Have you tried the "plugin" option that is listed under Mini Connected? You do NOT have to be running the mini connected app to get this. This is the feature that supports the "iPod Out" feature built into the iPod operating system. Basically, it replicated the iPod classic menu system right on the mini connected screen. It is MUCH easier to use than the menu system that you get by accessing the iPod via the "external devices" menu option under multimedia.
I have only used "Plugin" with an iPhone, but it should work with an iTouch and the iPod Classic (these three models were listed by Apple to support the iPod Out feature).
Old Mar 28, 2011 | 12:53 PM
punkrockdoc
When using the external devices menu, don't select a track - leave it at "all tracks" and hit play. Then it will play the whole album. When you select a particular track, it puts that track on repeat.
But, see my post above. The "Plugin" way is sooooo much easier to use.
Old Mar 28, 2011 | 03:25 PM
chaos_'s Avatar
chaos_
haha... yeah, what he said...
just ran the classic through my the countryman,,, left the second gen at work... but... yeah see above.
Old Mar 28, 2011 | 07:48 PM
pistolpepe33
thanks guys will try both options.....
Old Mar 29, 2011 | 11:21 AM
tonypjr's Avatar
tonypjr
what you are essentially doing is telling the radio to play a certain track. You need to go into an album or a playlist so it can play the album or playlist in order for your mini to play all the songs on a given album or playlist. if you go to songs and select a song and only that song is listed it will play that song alone then stop because there isn't another listed within that list. Hope this clears things up for you.
Old Mar 29, 2011 | 01:47 PM
pistolpepe33
tried using "plug In" feature but it did not recognize it...thanks anyway
Old Mar 29, 2011 | 08:09 PM
pistolpepe33
thanks it works......plug in didn't but listening to tracks correctly now thanks
RobbyD
Jan 29, 2019 01:22 PM
pglgp1292
Aug 9, 2017 12:45 PM
gar56
Nov 15, 2016 06:41 AM
krohm
Sep 28, 2015 12:16 PM
deep72
Sep 16, 2015 08:53 PM
