Drivetrain what would happen if.....
Old Mar 24, 2011 | 10:35 AM
Mini for life!'s Avatar
Mini for life!
i would delete the hose that goes from the supercharger bypass valve to the intake manifold and seal off the manifold. so im guessing the bypass valve would vent to atmosphere causing sound? im asking bechause the hose is getting kind of crusty i dont know why so im probaly going to delete it but i thought i should ask 1st
Old Mar 24, 2011 | 12:46 PM
DaveTinNY's Avatar
DaveTinNY
I'd buy a replacement hose and install. I suspect they designed these hoses into the system for a reason.
Old Mar 24, 2011 | 01:31 PM
Mini for life!
It can't be vented to atmosphere?
Old Mar 24, 2011 | 05:57 PM
NMgokart's Avatar
NMgokart
Replace the hose. Period. If you still have issues, diagnose from there.
Are you really qualified to re-engineer a car?
Old Mar 24, 2011 | 06:43 PM
Mini for life!
No need for jokes. Im just askingg because I seen a supercharged car with a bypass valve vented to atmosphere.
Old Mar 24, 2011 | 08:49 PM
firehawk618's Avatar
firehawk618
You'll get a WOOOSH sound, and the car will go rich for a second every time you go from boost to vacuum.
Likely get a CEL too.
Old Mar 25, 2011 | 06:04 AM
Mini for life!
oh i see, it works like a recurculating bypass valve found on a turbocharged car?
Old Mar 29, 2011 | 10:09 PM
FlipSmini's Avatar
FlipSmini
I wouldnt. Atmosphere bypass or BOV's are used for turbocharged cars to not allow air back into the system and allow a loud WOOSH sound. Has no performance gains. On my 2001 audi s4 which is twin turbo it has bypass valves. The purpose of the bypass valves is to (1) take the strain off of the high pressure intake line (after turbo) to the intake manifold. (2) the bypass valve then diverts the air from the exhaust side of the turbine to the intake side of the turbine allowing it to have a high pressure on the intake side of the turbo allow it to spin quicker. Now bringing this to a supercharged car, it is not necessary to have a atmosphere bypass valve or BOV due to the same reasons. Think of it as a air splitter in front of the car, it does about the same purpose, creating a pressure difference. Now will you notice a difference between a atmoshpere valve and a bypass valve on a supercharged car... doubtfull... On my s4 i had a bypass valve go bad so it became a atmosphere bov and the rpms it took to start boost took longer.
Hope this helps. I dont know about throwing a code, and i dont see any damage by donig it, just make sure you dont let anything get inside the bypass valve or the opening into the intake. Dont need a peble getting sucked into your supercharger.....
Hope this helps.
Old Mar 30, 2011 | 01:24 AM
Eric_Rowland's Avatar
Eric_Rowland
I'm pretty sure if you let the BPV 'vent to atmosphere', your car would stop running if you lifted off the throttle. Air takes the least resistant path. When the BPV is shut, that forces air into the SC.
That said, people have tried zip tying or 'deleting' the BPV, at a cost of MPG. But if you really want your MINI for life, I'd just get a new hose.
Old Mar 30, 2011 | 06:31 AM
JumpingJackFlash's Avatar
JumpingJackFlash
Uh, some clarification needs to be made. You said the hose is going from the BPV to the intake manifold. This leads me to believe you have the VGS mod installed. From the factory, the BPV has a small hose that leads right to a vent port on the module itself. When the VGS mod is installed, it converts the BPV from vacuum-operated to boost-operated. If that's the case, you leave the small vacuum line on the vent port and just cap it off by putting a screw into the end of the hose. In both cases, no ports or lines should be open or venting to the atmosphere. That would cause boost/vacuum leaks, but I am not sure if that will necessarily cause any ECU codes to be thrown.
Read this thread to see what I am talking about: https://www.northamericanmotoring.co...ystem-vgs.html. You should only have to read the first page or two to get the just of the VGS mod.
scfiveo
Sep 27, 2019 02:27 PM
navybsn
Oct 4, 2015 03:27 PM
gknorr
Oct 1, 2015 09:20 AM
potterstein
Oct 1, 2015 07:10 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
