Just a Mini engine light on 2 codes P0113, P0342 any ideas?
Yesterday my 2007 regular Mini Cooper Automatic check engine light came on a start up. The RPMs was a little high at 1500 and bouncing around a little. It usually runs at 900-1000rpm at a stop. I drive it around a little bit and it's rpms were still a little high coming in to stops. So I took it to Autozone for they could read the codes. Later the light went off and this morning no issues but later in the afternoon it came on again. Any body have these issues or any idea what it could be? Thanks in advance. Codes are below it came up with.
Code 1 P0113:Intake air temperature circuit high
Code 2 P0342:CAMSHAFT POSITION SENSOR NO SIGNAL OR LOW SIGNAL
Which one?
My CEL is on and doing a scan I come up with the same code of P0342 Camshaft Position Sensor "A" Low. I see that there are 2 sensors. How do I know which one to replace? At close to $100.00 a piece I hate to replace the wrong one. Thanks.
Dec 23, 2015 10:36 AM
Drivetrain Won't hold idle after work performed
Lt. Dan
Aug 10, 2015 08:23 AM
quality_sound
Aug 7, 2015 09:36 AM
