Interior/Exterior English Oak on the door circular's.
Old Mar 12, 2011 | 06:07 AM
praecurvo's Avatar
praecurvo
I have the English Oak dash trim and on my door handles. How do I go about finding it for the door circulars other than the $250 each the dealership is charging? My 2011 MCS came with the piano black circulars which I am willing to trade if anyone wants them.
aaron
Old Mar 12, 2011 | 06:33 AM
white3's Avatar
white3
I also have the piano black and asked my dealer about ordering the english oak. Even though they show it as available for the 2011s, he said that he wasnt able to order them. He didnt find a listing for them in the parts catalogue. I too would love to make the switch.
Old Mar 12, 2011 | 06:45 AM
Surfink's Avatar
Surfink
I am in the same boat and have tried to find the circulars since they were first shown on the configurator. I don't think they ever made them...No part numbers at all..I have English Oak trim on my '09 Clubman and would love to "complete" the wood look with the door surrounds...Anyone have a picture of an actual car with the door surrounds?
Old Mar 12, 2011 | 06:10 PM
Sketch's Avatar
Sketch
They never made them. English Oak was only available for the driver/passenger trims, shift **** and steering wheel.
Old Mar 14, 2011 | 04:53 AM
praecurvo's Avatar
praecurvo
I will see what I can improvise and revive this thread when I have results.
aaron
Old Mar 14, 2011 | 11:41 AM
schatzy62's Avatar
schatzy62
Try Aesthetic Creations I bet he could do something for you.
http://www.aestheticreations.net/
Old Mar 14, 2011 | 03:35 PM
jbewley's Avatar
jbewley
Something like this?
Old Mar 14, 2011 | 04:28 PM
Surfink's Avatar
Surfink
Is that factory parts or a vinyl wrap? If Factory, could you spill the parts #?
Old Mar 14, 2011 | 05:40 PM
praecurvo's Avatar
praecurvo
first off, please let us see a larger image...
secondly, what exactly does this picture represent and how does it relate to you?
aaron
Old Mar 14, 2011 | 05:41 PM
praecurvo's Avatar
praecurvo
thanks again schatzy.
Old Mar 15, 2011 | 01:26 PM
Dwight Walhood's Avatar
Dwight Walhood
Take a look at Sherwood Dash's products. They supply OEM replacement veneers as well as custom woods, too. I've got their walnut burl dash kit on, but still haven't decided whether to put on the ovals, too.
Old Mar 15, 2011 | 02:01 PM
praecurvo's Avatar
praecurvo
Called Sherwood, they don't make.
aaron
Old Mar 22, 2011 | 05:35 PM
jbewley's Avatar
jbewley
aaron
Firstly, it represents the passenger door of an R56 MC, which relates to me, because it just happens to be mine and secondly, if you look at my gallery you will see more pictures and where it came from.
Jim
Old Mar 22, 2011 | 06:30 PM
Dwight Walhood
Jim
Relates to me, too. I've got the exact same kit (walnut burl) on my R56, but only on the dash. Your Gallery pics finally convinced me to do the ovals, too. Did you DIY? If so, how do you get the ovals off to insure perfect alignment. I learned from the dash pieces that you only get one shot with that Kryptonite stick-um on the back of the veneer.
Old Mar 22, 2011 | 07:30 PM
jbewley's Avatar
jbewley
Use the little tube of stuff they give you and apply it mainly to the edges. I had my wife hold the piece at the exact spot on the front point of the oval, while I peeled and stuck it on from top rear to front, peeling off just a little backing at a time. I found the ovals easier to do then the dash sections. You have a little give to correct as you go, but not a lot, so go slow. Your are right, as you get only one shot. Mine has been on for two years, with no signs of letting go. Good luck.
Jim
Old Mar 23, 2011 | 07:01 AM
white3's Avatar
white3
I noticed on the Car ID website that they had a listing for OEM color under the wood section- anyone know if this is the English Oak that Mini provides? Or at least close in color to it? I would just like to add the English Oak to the ovals since I already have it on the dash.
Old Mar 23, 2011 | 08:24 AM
Dwight Walhood
Jim
Thanks Jim. Sounds like you put the veneer on with the plastic ovals still attached. I don't have that third hand to help, so will have to come up with a way to keep it centered. Putting that stick-em just on the edges sounds like the key. When I did the dash part I coated the whole thing so had zero wiggle room. Did figure out how to get the cover plates off otherwise it can't be done w/o looking like gack. Gotta show off how it came out after +1 year. Still getting !
Dwight
Old Mar 23, 2011 | 01:20 PM
jbewley's Avatar
jbewley
Dwight
There is a long thread around here someplace about those ovals. They don't come off. Well, they will, but you won't get them back on. They are attached with plastic, rivet like things which are heat welded. Even if you bought new ovals, there is no way, I know of, to put then back on.
Jim
Old Mar 23, 2011 | 01:25 PM
jbewley's Avatar
jbewley
When I got mine, Car ID said that the MINI English Oak could not be matched. Car ID is a distributer. The actual company is:
http://www.wowtrim.com/store/pg/17-O...-WOW-TRIM.html
Jim
USNAE2
16
Jun 17, 2022 07:17 AM
gar56
Nov 15, 2016 06:41 AM
jeri534
Nov 6, 2015 01:40 PM
torpeau
Oct 8, 2015 11:10 AM
patsum
Oct 1, 2015 06:33 AM
