Add me to the List of my Wife called me with and oil Leak
Old Mar 10, 2011 | 12:04 PM
peter_sd's Avatar
peter_sd
I have a 2010 Mini and it is now in the shop with the Wonderful Timing chain issue. When i got there to pick her up it looked like the bottom of the car and the wheels had an oil bath also the ground was covered in oil.
It has been at the shop for almost a week now there was metal flakes in the oil pan so the are pulling things apart they are checking the rod bearings and everything i guess. I am just worried that they are going to do just enough so they wont have to replace the engine.
Old Mar 10, 2011 | 01:04 PM
MattSaint's Avatar
MattSaint
Wow! So sorry to hear that. Makes me awful nervous as I've already logged 21k on my 2010...
Old Mar 10, 2011 | 01:05 PM
pheatton's Avatar
pheatton
OK this like three in the past two weeks now I think.
Hope it all works out for you.
Old Mar 17, 2011 | 08:20 AM
peter_sd's Avatar
peter_sd
OK so i finally got an update from the dealer. 2 of the rod's are slightly bent they said there is nothing else wrong with the engine i am not thrilled at all that i have had to have a car with 15k miles on it have the engine torn apart. I asked MINI to replace the engine they will not do it all they want to do is replace the rods's and call it good.
Old Mar 17, 2011 | 08:41 AM
iwashmycar's Avatar
iwashmycar
least its only at 15K and you have a lot more time in case the rods alone dont quite get it.
should be fine though
Old Mar 26, 2011 | 06:14 PM
peter_sd's Avatar
peter_sd
Ok so another update the found more damage and are replacing the Engine. On a side not they have my wife a MINI to drive while her car is being fixes now that car's check engine light came on and is staying on.
Old Mar 30, 2011 | 03:54 AM
slinger688's Avatar
slinger688
Are they replacing your engine with another rebuilt one? Also get them to extend your warranty.
Old Mar 30, 2011 | 05:52 AM
peter_sd's Avatar
peter_sd
They said they are replacing it with a new engine i hope it is just not a rebuilt one. I am going to try to get MINI to extend the warranty also.
Getrieben
Aug 17, 2016 06:32 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
Powershift
Aug 16, 2015 05:14 PM
Emnotek
Aug 13, 2015 05:47 PM
azntaiji
Aug 13, 2015 03:24 PM
