Navigation & Audio Muddy Ipod!
Old Mar 10, 2011 | 06:13 AM
praecurvo's Avatar
praecurvo
Muddy Ipod!
I just picked up my '11MCS w/harmon kardon and the ipod/usb analog input is a muddy sounding bit, isn't it? The CD player/radio are clear as day, as is the usb flash drive, but the analog input...Mini should've worked a little harder on this one. Does anyone else experience this one?
aaron
Old Mar 10, 2011 | 06:52 AM
schatzy62's Avatar
schatzy62
There should be an input volume adjustment for the AUX in and that may make a difference. if it is set to high or to low it can have such an affect.
Look in you Manual to see how to adjust it.
Old Mar 10, 2011 | 07:00 AM
praecurvo's Avatar
praecurvo
I tried that already, but thanks for the input.
aaron
Old Mar 10, 2011 | 07:05 AM
schatzy62's Avatar
schatzy62
What cable are you using to connect the iPod to the car?
Old Mar 10, 2011 | 07:13 AM
praecurvo's Avatar
praecurvo
BMW 6fl
Old Mar 10, 2011 | 07:15 AM
praecurvo's Avatar
praecurvo
I tried my friends cable, his 2 ipods, and my ipod and they all have the same mucky sound. I believe it is the quality of analog AUX jack/AUX input to the head unit Mini uses. Perhaps I have to try another Mini, but my buddy's BMW sounds just fine.
aaron
Old Mar 10, 2011 | 08:15 AM
schatzy62's Avatar
schatzy62
The cable that you are using may be part of the problem. There are atleast 4 different cables and for a 2011 you must have the correct cable or there will be problems.
Where do you live?
Did the cable come with the car?
what options do you have on the stereo? (mini connect, visual boost (not in usa), bluetooth, etc)
How many silver bands are there on the tip of the plug that goes into the aux jack?
Is there a number on the cable you are using? there should be a number somewhere.
Old Mar 10, 2011 | 12:47 PM
praecurvo's Avatar
praecurvo
it was a dealer provided cable. 0440796 and it is a stereo (3 band) cable. I live in south florida and the options are bt\usb and of course hk.
thanks again,
aaron
Old Mar 10, 2011 | 06:13 PM
CaptainSteve's Avatar
CaptainSteve
I have the same options H/K and USB/BT option. I don't think the iPod sound is murky at all, in fact I think it sounds about the best of all the inputs I've used, radio (HD channels included) and SAT, haven't tried a CD yet.
I think I might have played a bit w/ the EQ settings on my iPod when I first put the iPod in the car. Might be worth tinkering with.
Old Mar 10, 2011 | 07:00 PM
praecurvo's Avatar
praecurvo
THanks captain, but I have already tried that. I am coming to believe that perhaps it is the actual aux jack itself with the issue. I am not sure how that can be, but perhaps this forum can shed some light. Honestly though, I truly do not mind at all using my memory stick! It works great, it is little, and sounds like it should.
aaron
Old Mar 11, 2011 | 06:03 AM
schatzy62's Avatar
schatzy62
thanks again,
aaron
That is the correct cable. So there could be a problem with the wiring in the car or the ULF module could be bad. doubtful it the actual jack but anything is possible.
Old Mar 11, 2011 | 08:37 AM
praecurvo's Avatar
praecurvo
ULF module? And how could the wiring be bad?? THanks again.
aaron
Old Mar 11, 2011 | 09:55 AM
schatzy62's Avatar
schatzy62
ULF module is the module that controls bluetooh USB and AUX inputs.
If there is a bad connection or broken wire (ground) those could be causing bad sound reproduction.
Or the aux circuits in the ULF could be not functioning properly.
Old Mar 12, 2011 | 05:59 AM
praecurvo's Avatar
praecurvo
I am only curious as to how I can get them to diagnose this issue. If I decide to bring it in, I will let you know.
aaron
RobbyD
Jan 29, 2019 01:22 PM
pglgp1292
Aug 9, 2017 12:45 PM
gar56
Nov 15, 2016 06:41 AM
krohm
Sep 28, 2015 12:16 PM
deep72
Sep 16, 2015 08:53 PM
