Blinking lights and the Sunroof
Old Feb 18, 2011 | 10:02 AM
Phlerb's Avatar
Phlerb
My MCCs just got done a checkup, and I had mentioned that the drivers headlight was blinking 3 times at startup, and I have had episodes of Lamp warning lights and once the directional was blinking 6 times fast instead of the normal 3 times slow for a whole trip.
They SA said that it was a bad FRM(?) Module that was bad because the drains in the sunroof were not draining properly and the water was draining down into the module.
This is more of a FYI post than a "What is wrong now?" post!
Milage is 39,000
Also fixed:
Belt Tensioner
Broken Hood Release Latch
New Intake for rough cold idle
Door sill plate that was peeling off
To Be Done later:
Need to get unpainted Hood Scoop Painted and installed
Drivers Rear window bottom 3 defrost wires not working, need to set up appt with dealer for 3rd party to install new glass
Old Feb 18, 2011 | 12:30 PM
schatzy62's Avatar
schatzy62
Yeah the Sunroof drains can be a problem and if they are clogged water will enter the car. Seems a common problem on many makes and models though.
As for a wet FRM module - Yeah that could cause the problems with the lights
Door sill plate - seems to be a common problem as well
Intake another sort of common problem - not as much so as the others above
Broken hood latch - not such a common problem that I can remember. but hey it is mechanical and mechanical things break.
Dec 23, 2015 10:36 AM
missinmyjeep
Aug 22, 2015 07:13 PM
dscott90000
Aug 21, 2015 07:07 PM
Lschneider
Aug 21, 2015 02:21 AM
