cylinder head removal HELP!!!
Old Feb 10, 2011 | 07:30 AM
mini cooper's Avatar
mini cooper
I have a 2008 cooper S with 110,000 miles on it. I changed the sparkplugs with NGK's.... after about 15000 miles the number 2 cylinder plug came apart and has damaged a exhaust valve Compression is 0 and the leak down test indicated that the exhaust valve will not close...So i need to remove the head i am looking for anyone that has done this, that may be able to give me some pointers on how the best way to remove the exhaust manifold and any other tricks....thanks in advance.
Old Feb 10, 2011 | 07:49 AM
mini cooper
here is a pic of the plug
Attachment 51601
Old Feb 10, 2011 | 08:51 AM
EuroTechsAZ's Avatar
EuroTechsAZ
Its requires special tools. I own the Koch tools and they are a spot on copy of factory set. You do not need to remove the turbo. Put vehicle in service mode(front end pulled foward), Remove the cat, release all hoses from turbo, remove front mount ,remove intake, unbolts thermostat housing from head. Once your inside the engine , simply lock crank and cams, remove timing gears,guides, and chain. Then remove head. That is the super cliff noted version, but make sure you get new cam bolts and crank bolt they are torque to yield.
Old Feb 10, 2011 | 09:07 AM
mini cooper
i have ordered the timing chain removal tool from Koch is there other special tools required? Could you elaborate on "putting vehicle in service mode"?
Old Feb 10, 2011 | 09:38 AM
EuroTechsAZ
service mode. remove headlamps, remove 4-13mm bolts from upper rad brace, remove 3 10mm bolts from rad brace, remove clip for washer bottle from rad support. remove hood release cable on driver side. remove trim above fog lamps,remove 4-13mm nuts and there will be holes to install long guide bolts. 6-7inch long. remove grille and remove 2-13mm nuts. remove front half of fender liner trims for access to 4-13mm bolts where lower subframe attaches to front core support. remove fender trims and release clips securing trims to bumper. after thats all done the front clip will slide forward 6-7 inches. no need to drain coolant or anything they left enough slack in hoses. walking you thru this on memory so i may have missed a few small things but those are the large points
Old Feb 10, 2011 | 10:00 AM
mini cooper
thats pretty cool information thanks, i will take pictures as i go through this i am sure it will be helpfull to others.
Old Feb 10, 2011 | 03:16 PM
etalj's Avatar
etalj
definitely post pics!
Old Feb 10, 2011 | 03:25 PM
Oreod's Avatar
Oreod
Better minds than mine will know, but that plug looks burnt to me. There may be something else going on.
gary
Old Feb 11, 2011 | 09:12 AM
mini cooper
you might be right about the plug being burnt from something else, i am sending the plug to NGK to have it looked at, i am sure they will tell me there opinion of the plug. I still have to remove the head though because i know positively there is valve damage, i am just hoping i dont have any cylinder wall damage. all of the other plugs look fine, i guess it is possible that an injector was fouling causing a lean condition?
Old Feb 11, 2011 | 09:50 AM
minimize07's Avatar
minimize07
OMG ,110,000 in an '08.Now there's someone lovin their Mini
Old Feb 11, 2011 | 03:52 PM
mini cooper
not sure about "lovin" the mini right now...lol ...we will see how the weekend goes.
Old Feb 14, 2011 | 10:24 AM
ghurm001's Avatar
ghurm001
so.. how'd the weekend go for you? I've got my '03 R50 apart in my garage right now due to a blown head gasket (overheated due to fan failure)..
I've got pretty much everything lined up and ready to take out, exhaust is loose, intake is loose, everything else is removed except the timing chain, it's tensioner, and the head itself...
what is this KOCH tool you all are talking about? and can I get away without it?
Any pointers you've got on taking that chain off?? (even though I guess they may not apply 100% since i'm an older non-S)
Here's the thread I started the other day
Thanks!
Old Feb 18, 2011 | 03:07 PM
mini cooper
I am not familiar with the R50 but you cant do a proper timing without the Koch tool set on a R56, It positions the cams and puts the engine in a 90 degree position. I purchased a ported and polished head and i will be doing the install this weekend along with a water/meth injection and an oil catch can the valves were very carboned up. i have pics that i will post once this project is done
Old Feb 18, 2011 | 03:11 PM
ThumperMCS's Avatar
ThumperMCS
Where'd you get the head from?
Old Feb 19, 2011 | 07:38 AM
mini cooper
i got the head from a guy in florida odly enough it has a TPR stamped on the exhaust side of the head....have any idea who made that one...
Old Feb 20, 2011 | 07:25 AM
scottab36's Avatar
scottab36
Keep us posted!!
Old Feb 20, 2011 | 06:33 PM
etalj's Avatar
etalj
Could it be a Thumper Head?
Manny_cooper
17
Nov 1, 2024 07:46 PM
Teh
Aug 22, 2022 04:37 AM
bobbiemartin
Jan 20, 2016 05:28 PM
greekzilla
Aug 23, 2015 03:44 PM
MIminiclubman
Aug 5, 2015 09:14 PM
