R60 Slow To Heat Up, is this the Norm?
After 2 months with the ALL4, we really have only one issue/complaint...it takes FOREVER to get warm air from the heater. Once it is up to temp, turn it down as the output is great. As I see some others have also noted this issue, I can not blame the cold Iowa winter. Thank goodness for the heated seats, but I still ask WHY so long?
Is this an issue with this family of engines? My 02 warms up rapidly, but the engine family is different.
Thoughts?
Thoughts?
Thoughts?
Thoughts?
I don't have a Countryman, but my Clubman takes several minutes to warm up (heater). It's cold in the morning, below freezing, but not THAT cold compared to other parts of the country. Heated seats warm QUICKLY, however
I wonder if it's just something to do with this family of engines, as my '09 Clubman S seems to take a long time before I feel much heat too, especially on these single digit temp days.
I'm going to put my Garmin Eco module back in and see if I can see how long it takes to get up to temp - and try and learn whether it's an engine temp thing or maybe a heater thing going on...
You want the entire country to move to So. Florida, or only all the MINI owners north of you? Might get a bit crowdish if they did.....
This could be cause by the thermostat stuck in the open position. Normally, during initial cold start ups the thermostat is in the closed position bypassing the coolant flow to the radiator. This allows quick warm ups, when to coolant reaches the thermostat rated temperature it opens up the path to the radiator allowing normal cooling flow.
Warmup
... Normally, during initial cold start ups the thermostat is in the closed position bypassing the coolant flow to the radiator. This allows quick warm ups, when to coolant reaches the thermostat rated temperature it opens up the path to the radiator allowing normal cooling flow.
It really does take the MINI engine a while for everything to get up to normal operating temperature. The engine coolant is only half the story - I have an oil temperature gauge on my '06 R52, and while the engine coolant is normally up to operating temperature in 10-15 minutes, it can easily take 25-30 minutes before the oil temperature stabilizes.
hays0023
Oct 31, 2015 07:52 PM
