R60 Slow To Heat Up, is this the Norm?
Old Feb 9, 2011 | 05:06 PM
FiremanMike's Avatar
FiremanMike
After 2 months with the ALL4, we really have only one issue/complaint...it takes FOREVER to get warm air from the heater. Once it is up to temp, turn it down as the output is great. As I see some others have also noted this issue, I can not blame the cold Iowa winter. Thank goodness for the heated seats, but I still ask WHY so long?
Is this an issue with this family of engines? My 02 warms up rapidly, but the engine family is different.
Thoughts?
Old Feb 9, 2011 | 05:15 PM
FatBob's Avatar
FatBob
We traded a BMW 135 for the Mini. It was slow to heat as well. Im not sure if its a BMW trait or just these engines.
Old Feb 9, 2011 | 05:34 PM
miniobx's Avatar
miniobx
Thoughts?
I'm finding it takes 12-15 minutes BEFORE THE heat starts pumping. Lars car that took that long to warm up for me was my 1968 Valiant! Of course, my check engine light is on too so I'm wondering if this is a recall issue?
Old Feb 10, 2011 | 07:44 AM
minicoopermike's Avatar
minicoopermike
I don't have a Countryman, but my Clubman takes several minutes to warm up (heater). It's cold in the morning, below freezing, but not THAT cold compared to other parts of the country. Heated seats warm QUICKLY, however .
Old Feb 10, 2011 | 08:24 AM
MINIdave's Avatar
MINIdave
I wonder if it's just something to do with this family of engines, as my '09 Clubman S seems to take a long time before I feel much heat too, especially on these single digit temp days.
I'm going to put my Garmin Eco module back in and see if I can see how long it takes to get up to temp - and try and learn whether it's an engine temp thing or maybe a heater thing going on...
Old Feb 10, 2011 | 10:42 AM
jondfishman's Avatar
jondfishman
Move to Southern Florida, I've never used my heater:P
Old Feb 10, 2011 | 11:07 AM
MINIdave's Avatar
MINIdave
You want the entire country to move to So. Florida, or only all the MINI owners north of you? Might get a bit crowdish if they did.....
Old Feb 11, 2011 | 09:09 PM
mini_z's Avatar
mini_z
I feel the same with my CM. Good thing for the heated seats.
I though i was getting OLD and feeling the cold now lol
Old Feb 11, 2011 | 09:46 PM
kaneguy's Avatar
kaneguy
This could be cause by the thermostat stuck in the open position. Normally, during initial cold start ups the thermostat is in the closed position bypassing the coolant flow to the radiator. This allows quick warm ups, when to coolant reaches the thermostat rated temperature it opens up the path to the radiator allowing normal cooling flow.
Old Feb 12, 2011 | 09:04 AM
prm1177's Avatar
prm1177
Warmup
Originally Posted by kaneguy
... Normally, during initial cold start ups the thermostat is in the closed position bypassing the coolant flow to the radiator. This allows quick warm ups, when to coolant reaches the thermostat rated temperature it opens up the path to the radiator allowing normal cooling flow.
Conversely, some cars close the flow to the heater core during warmup to accelerate this process as well. As folks on this thread are commenting on a slow heater warm-up, it might be this system some folks are seeing. It was the same in most of the BMWs I've owned.
Old Feb 12, 2011 | 05:03 PM
ufomini's Avatar
ufomini
My 06 R53 takes at least 10-15 minutes to really warm up. Thank goodness my seats are warm in about half that time!!!
Old Feb 12, 2011 | 05:50 PM
miniobx's Avatar
miniobx
Interestingly, I am finding more reasonable warm up times now ~ 3-5 minutes. Of course, my check engine light is no longer on and the temperatures here in the northeast are not sitting close to zero any more.
Old Feb 12, 2011 | 06:56 PM
inimini2007's Avatar
inimini2007
My CM warms up in 5-8 minutes.
Old Feb 13, 2011 | 04:27 AM
mattmed03's Avatar
mattmed03
My 08 clubman s heats up in 5 min or less.
My CM takes 10-15 min before heat blasts thru in auto mode. It is a bit weird. It has also been significantly colder this year!
Old Feb 13, 2011 | 07:11 AM
ScottRiqui's Avatar
ScottRiqui
It really does take the MINI engine a while for everything to get up to normal operating temperature. The engine coolant is only half the story - I have an oil temperature gauge on my '06 R52, and while the engine coolant is normally up to operating temperature in 10-15 minutes, it can easily take 25-30 minutes before the oil temperature stabilizes.
boholio
Nov 9, 2015 03:50 PM
hays0023
Oct 31, 2015 07:52 PM
ryGuyMCS
Oct 6, 2015 12:04 PM
Sep 3, 2015 01:45 PM
