Anyone running 215/35R18 on their GP?
Old Feb 9, 2011 | 09:47 AM
el chupacabra's Avatar
el chupacabra
Anyone running 215/35R18 on their GP? And if so what brand, do you have any spacers? Thanks
Old Feb 9, 2011 | 09:56 PM
howsoonisnow1985's Avatar
howsoonisnow1985
I was considering, but went with 225/35-18, needed spacers and 5mm did the trick.
Old Feb 9, 2011 | 10:20 PM
el chupacabra
Thanks for the info much appreciated. I need tires now and wanted a size up since tire brand options are kinds of limited for the 40 series in the 205. And I dont like cheap brands that's why nor runflats.
Old Feb 10, 2011 | 06:43 AM
quikmni's Avatar
quikmni
I went with 215/40 to have a little more sidewall than the 35 series. Worked fine with stock GP wheels but is a little close on the inside.
Old Feb 10, 2011 | 07:15 AM
THE ITCH's Avatar
THE ITCH
Quick
Which brand of tire did you go with? Just to be sure you are not running any spacer with it, correct.
Thanks, Steve
Old Feb 10, 2011 | 08:32 AM
el chupacabra
And you are running 15mm spacers with the 215's? I saw under your description? Because im considering going with the 215's with a 5mm spacer. If you have a pic that would be great. Thanks again.
Old Feb 10, 2011 | 07:38 PM
quikmni's Avatar
quikmni
Originally Posted by THE ITCH
Quick
Thanks, Steve
I have had 215/40-18 Toyo T1R and now have Hankook Ventus V12 EVO.
I had the Toyo T1R installed on stock wheels with no spacer and they did not rub on the inside or outside. I now use the stock wheels with 15mm spacers. I installed the Hankooks after I installed the 15mm spacers. Both the Toyo and Hankook tires rub on the outside with the spacers (required a little wheel arch and wheel well liner trimming).
Old Feb 10, 2011 | 07:54 PM
quikmni's Avatar
quikmni
I previously posted some photos to the following thread that should still be viewable:
https://www.northamericanmotoring.co...-question.html
I believe about Post #3 in the thread.
Old Feb 10, 2011 | 08:07 PM
el chupacabra
Thanx for doing that. Saw the pics and that helped me out, as well as the input.
Old Feb 11, 2011 | 07:03 AM
THE ITCH's Avatar
THE ITCH
Quick
Thanks for the information. As you probably know the tires available for the 18" wheels is getting smaller all the time. I will probably get one more summer out of the Michelin PS2's and then have to find a substitute as that size
205/40 is no longer made.
I have been looking at the Hankook's. How do you like the 215 size in that brand and do you feel that they would fit without rubbing like the Toyo's did? I would prefer not to run spacers unless I had to.
Thanks, Steve
Old Feb 11, 2011 | 07:59 AM
quikmni's Avatar
quikmni
Steve,
I believe the Hankook 215/40-18 will fit the stock GP wheels without spacers and with no rubbing because based on manufacturer numbers the section widths are the same. The amount of negative camber you run might make a difference because the rub will be at the inside so here is what I run; Front -2.1 deg and rear -1.6 deg.
From what I recall I had around a pencil width of clearance with the 215/40 T1Rs.
In general I liked the Toyo T1R better but it was difficult to obtain last time I needed tires so I switched to the V12. However, the V12 is a good tire so far. I mainly do street driving and have done one Auto-X with the V12s. I think the T1R performed slightly better at the very tight (lower speed) Auto-Xs that I have attended.
Mike
Old Feb 13, 2011 | 06:49 AM
THE ITCH's Avatar
THE ITCH
Mike
Thank you for the information. I had noticed that the section widths were identical but some times they have a different way of measuring the same thing.
Did you notice the slight difference in gearing because of the increase in oal diameter? It is only .400 in diameter which would equate to a little more than 3/16 in thread depth. I can't say that I notice a difference between a fresh set of tires and ones that are ready for replacement.
Thanks again, Steve
Steve,
Mike
Old Feb 13, 2011 | 08:58 AM
quikmni's Avatar
quikmni
I did not notice any difference in gearing or acceleration. I calcuated the diameter difference at 0.31 or about 1.3% (not enough for me to notice).
Old Mar 15, 2011 | 09:29 AM
GokartPilot's Avatar
GokartPilot
I am running 215/35s and there is a 3 mile an hour diffrence according to the GPS. If anything it has keeped me a little low in the speed traps.
Kimolaoha
Dec 5, 2020 09:32 PM
xpunisherx
Nov 27, 2015 03:32 PM
Nine Plan Failed
Oct 14, 2015 11:50 PM
Tektura
Tires, Wheels, & Brakes
18
Sep 13, 2015 10:00 AM
