R50/53 Help, what is code P1498
Old Feb 5, 2011 | 02:21 PM
Checkmate_2006's Avatar
Checkmate_2006
I just installed my boost gauge and volt gauge. I now have pending code P1498. What is it?
Old Feb 5, 2011 | 04:44 PM
checkers's Avatar
checkers
Just go to search and input P1498
Old Feb 5, 2011 | 06:35 PM
HRM's Avatar
HRM
this thread says it is likely a vacuum leak.
https://www.northamericanmotoring.co...ault-mean.html
With a boost install I would check all connections.
Old Feb 5, 2011 | 08:14 PM
Crashton's Avatar
Crashton
I don't know what that code is but I'd guess it has to do with your boost gauge install. Vacuum leak where you've hooked the probe?
Old Feb 5, 2011 | 08:18 PM
Checkmate_2006
Well I couldn't find the code, but I did remove the intercooler and underneath I found there was a small kink in the the coming from the fuel pressure regulator and the hose was not on tight enough. Once those problems where corrected I retested everything, the code cleared and the gauge was working properly
Old Feb 5, 2011 | 08:52 PM
jeffster06's Avatar
jeffster06
In my experience the 1498 is a vacuum fault most likely the hose you found is what caused it.
Old Feb 5, 2011 | 09:39 PM
Checkmate_2006
thanks everyone. glad its fixed.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
olson187
Sep 18, 2015 10:26 AM
Mini Hooper
Sep 17, 2015 01:58 PM
Enjoytheride
Sep 17, 2015 12:10 PM
