Drivetrain 25 PSI off stock supercharger
Old Jan 29, 2011 | 06:12 PM
Fatherdeth's Avatar
Fatherdeth
So, here we go again. I keep tripping a Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction CEL. The car acts like it has pep, but once you accelerate and start gaining speed it acts like it's starving for fuel. Toake matters worse, the boost gauge starts to go over 25 psi!!!! I don't know what's going on with this car, but it's really ticking me off. Standard mods. 15% s/c pulley, 2% oversized crank pulley, CAI, and recently I reverted back to an OEM bypass valve. 1 year ago I changed both MAP sensors. Anybody want to chime in?
Old Jan 29, 2011 | 06:17 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Sounds like a MAP sensor issue. Have you tried geting the ECU reset?
Old Jan 29, 2011 | 06:18 PM
Revolution Mini Works's Avatar
your cat is plugged
Old Jan 30, 2011 | 04:31 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
My 83' GTi had a bad cat. Golf ball size chunks of ceramic inside would settle until I gave it some gas at which time these chunks would relocate to the back of the cat output effectively blocking exhaust flow.
How good are the free flow cats as a replacement. Any drawbacks on a daily driver ? Inspection issues ?
http://www.youtube.com/watch?v=6tKt4KTfppA
Old Jan 30, 2011 | 11:20 AM
mini_racer's Avatar
mini_racer
Yep, the cat.
Old Jan 30, 2011 | 11:25 AM
FlynHawaiian's Avatar
FlynHawaiian
Magnaflow makes California Legal ones. They are a subpart number I believe, called the California CARB Compliant. I believe you get a 4 year, 50k mile warranty on them.
Old Jan 30, 2011 | 03:05 PM
Fatherdeth's Avatar
Fatherdeth
Originally Posted by Revolution Mini Works
your cat is plugged
So obviously that's why my muffler shakes so violently when I shut her down and it crackles and pops from the heat. So, I guess I'll be pulling the cat off. I take it the plugged converter causes too much back pressure on the engine? Thanks Way and everybody else who chimed in.
Old Jan 30, 2011 | 03:44 PM
BadMINI S's Avatar
BadMINI S
Its not just an obsession
i have a new magnaflow cat for sale if you're interested
Old Jan 30, 2011 | 05:36 PM
Fatherdeth's Avatar
Fatherdeth
Can you PM me with a price?
sevin
May 2, 2026 06:11 AM
Dec 5, 2016 06:31 PM
tr3y003
Oct 22, 2015 10:48 AM
gmonde
Sep 8, 2015 06:37 AM
