R50/53 How to remove the rear view mirror
Old Jan 17, 2011 | 04:28 PM
gabber's Avatar
gabber
I want to add a auto dimming mirror. Does anyone know how I take it off? First I want to check to see if its pre wired. Does anyone know?
Old Jan 17, 2011 | 08:38 PM
Checkmate_2006's Avatar
Checkmate_2006
I added the autodimming mirror with homelink last week. Twist the mirror 90 degrees right or left and the mirror will come off the stud on the headliner. The back housing around the stem comes apart in two peices and you can then unplug the cable from the mirror. The mirror is prewired for autodimming.
Check out this link: https://www.northamericanmotoring.co...n-my-06-a.html
Old Jan 17, 2011 | 08:40 PM
mini53's Avatar
mini53
I dug around for 15 minutes and couldnt find a place to plug one in on my 2002 Cooper S. There was a module that said 315mhz bolted up there, what is that, the alarm?
Old Jan 17, 2011 | 08:43 PM
gabber's Avatar
gabber
Great! I appreciate your help. Im going to order tomorrow morning! :D
Old Jan 17, 2011 | 08:48 PM
Checkmate_2006
The 315Mhz has something to do with the keyless remote. If you purchase a new mirror from Classic MINI it will have a 315MHz module in the new mirror already. I sold my manual dip mirror for $90 on the Marketplace.
The new Autodimming mirror with Homelink cost me $345 from Classic MINI.
http://www.realoem.com/bmw/showparts...=51&fg=40&hl=6
http://www.realoem.com/bmw/showparts...=51&fg=40&hl=3
By the way, those part numbers are for a MINI Coopers S Build date Feb. 2006
Old Jan 17, 2011 | 09:00 PM
gabber's Avatar
gabber
WoW! $90 for the manual dimming mirror? Ill make sure to post it up there once I do the swap.
Old Jan 17, 2011 | 09:04 PM
Checkmate_2006
Yeah I was actually surprised it sold for so much. It helps take the bite out of the upgrade cost for sure.
Old Jan 19, 2011 | 10:46 AM
BMWNTHZST's Avatar
BMWNTHZST
I have a March '05 built Cooper S. How do I know if I already have the 315 MHZ or if I need it? They are two separate mirrors:
http://www.realoem.com/bmw/showparts...77&hg=51&fg=40
This is an upgrade I want to do too!
Old Jan 19, 2011 | 10:55 AM
Checkmate_2006
The two mirrors are auto dip, but one has Homelink the other doesn't. I have a Feb 06 build and used the part 51169134363. I was able to get this mirror from Classic MINI in OH for $345. Your car is prewired for the autodip mirrors, just chose either the mirror with homelink or the other without. The 315Mhz is built into both mirrors already.
Old Jan 19, 2011 | 11:32 AM
BMWNTHZST's Avatar
BMWNTHZST
Thanks for the fast reply
Old Nov 29, 2011 | 11:03 AM
scf's Avatar
scf
If buying a mirror off of Ebay, how would I tell if it's auto dimming/dipping or not? Aside from their description of course.
Old Nov 29, 2011 | 12:26 PM
BMWNTHZST's Avatar
BMWNTHZST
Don't quote me however I think you will see a photo cell (small black dot) in the center of the lower part of the mirror.
Old Nov 20, 2012 | 01:51 PM
All4mini's Avatar
All4mini
Sorry to resurrect an old thread - but - I plan on removing the Stock mirror on my wife's 2012 Countryman to replace it with a rearview mirror with a monitor for a rear camera -(yes, I know, why - My wife wants it). The information about the 315MHz module in the mirror concerns me. Is this module for the remote entry system? In which case the rearview mirror replacement is out of the question.
TIA
Michael
Old Dec 11, 2012 | 11:51 AM
SuprCoop's Avatar
SuprCoop
All4mini, you're asking in a 1st gen thread, FYI.
Old Dec 12, 2012 | 05:44 AM
All4mini's Avatar
All4mini
Thanks - did not notice the location - just the topic
Old Nov 21, 2014 | 11:35 AM
MiniKJ's Avatar
MiniKJ
Sorry to renew this thread folks. I have a 2006 MCS and just received a replacement auto-dim/UGDO mirror from vendor. My wife's car has its auto-dim feature went out with a big stain in the middle of the mirror. My question is, will the factory remote work after the plug and play swap? Or do I need to program the remote? Thanks for any help provided.
Old Nov 21, 2014 | 11:38 AM
BMWNTHZST's Avatar
BMWNTHZST
It is a simply plug and play no reprogramming required!
Old Nov 21, 2014 | 11:55 AM
MiniKJ's Avatar
MiniKJ
Thank you for such quick response. It's interesting that I found the replacement unit design is slightly different even the size and buttons are all the same. There's an additional hole on the back casing (not the light sensor hole). It appears to be serving as ventilation for internal components? There's nothing in there and I could see the mirror when shining a flashlight into the hole. Has anyone noticed or encountered this? I hope I'm getting the correct part, but not one for new MINI.
Dec 23, 2015 10:36 AM
dyeLucky
Sep 11, 2015 10:41 AM
caiken
Aug 27, 2015 06:55 AM
Bennyboy
Aug 18, 2015 07:28 AM
dyeLucky
Aug 7, 2015 07:10 AM
