Suspension Lowest Lowering Springs?
Old Jan 10, 2011 | 03:00 PM
MiniHCP's Avatar
MiniHCP
Cant decide on the springs i wana get not lookin to get coilovers for awhile inless i see a steal of a deal so i want the lowest drop till i do
Tein? M7? Hsport? eibach? ect... whats the best?
Thanks HCP
Old Jan 10, 2011 | 03:36 PM
quikmni's Avatar
quikmni
H&Rs drop about an inch, maybe a little more. There are a progressive rate so not any rougher than stock on the street.
Old Jan 10, 2011 | 04:05 PM
wrh3's Avatar
wrh3
I am happy with my Apex springs Linear like OE and a great value too.
http://www.mossmini.com/Shop/ViewPro...eIndexID=94666
Old Jan 10, 2011 | 04:09 PM
MiniHCP's Avatar
MiniHCP
wow great price and liking the stance
Old Jan 10, 2011 | 04:17 PM
MINI33342's Avatar
MINI33342
.....and it's riding on the bumpstops too!
Be careful with max drop springs as the MINI does not have a lot of travel stock.
Old Jan 10, 2011 | 04:47 PM
gschiel's Avatar
gschiel
Are those Apex springs mounted on stock shocks?
Old Jan 10, 2011 | 04:51 PM
wrh3's Avatar
wrh3
Yes, about 15k miles on the springs. I am the second owner and have had the car since it was at 109k miles, almost at 140k miles now ~year later. Dampers are OE as far as I know but most of the miles have been highway between the first owner and myself, and I occasionally go on spirited mountain drives with some of the local car groups. My last drive with the Lotus group was an eye opener for them, I don't think some of them thought a Mini could keep up much less be in front of most of them
Dampers still work fine and are not leaking as of a few weekends ago.
Old Jan 10, 2011 | 05:31 PM
Blackbomber's Avatar
Blackbomber
Real sharp, wrh3. What size tires are those?
Old Jan 10, 2011 | 05:47 PM
wrh3's Avatar
wrh3
Thanks, Hankook Ventus V12 Evo 215/45/17
Old Jan 10, 2011 | 06:31 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If your looking to get real low, save your money and check out the Vmaxx coilovers they are cheap and will get you down low.
Old Feb 2, 2011 | 06:22 PM
nopistons's Avatar
nopistons
How much the Apex springs lower your car and how is the ride?
Old Feb 2, 2011 | 06:25 PM
wrh3's Avatar
wrh3
I didn't measure before and after so I can't comment on how low. To me it may ride a bit better, definitely not any rougher.
Old Feb 2, 2011 | 07:04 PM
nopistons's Avatar
nopistons
Did it come with shortened bump stops or do they recommend cutting the stock bump stops?
Old Feb 8, 2011 | 10:13 AM
Fizzyx's Avatar
Fizzyx
This is not really accurate.
If you compare two hypothetical springs that dissipate the same energy over the range of suspension travel, one being a linear rate and one being progressive rate, the progressive will be 'softer' on smaller bumps but 'harder' on big bumps.
Also, with progressive springs, your suspension will, on average, travel more. On an already lowered car, especially with a strut-type suspension, this means that geometry can suffer.
Old Feb 8, 2011 | 07:10 PM
andyroo's Avatar
andyroo
And with a drop over an inch, you have over an inch less travel to soak up bumps. Big drops with springs is a bad idea on the Mini, if you care about handling and ride quality. Not enough travel.
- andrew
Old Feb 8, 2011 | 07:54 PM
MiniHCP's Avatar
MiniHCP
im going with a set of vmaxxs, just got a raise so ill treat myself
Old Feb 8, 2011 | 07:57 PM
kb30's Avatar
kb30
thanks for the pics of car on apex springs. i have had a set since last june. i need to put them on one of these days, im just too lazy to get around to it
Old Feb 8, 2011 | 09:04 PM
spinned's Avatar
spinned
H&R RSS will put it near the ground. I had to raise mine.
patsum
26
May 29, 2021 06:29 PM
Supertractor3
Apr 7, 2017 11:16 AM
ej
Nov 17, 2015 09:21 PM
Sep 3, 2015 02:06 PM
Sep 2, 2015 11:15 AM
