R50/53 Changing R53 JCW intake to Alta CAI
Old Jan 1, 2011 | 07:50 PM
vinno's Avatar
vinno
Hi, I was wondering if any of you out there have been in this same situation- and if you have any pearls of wisdom. I have looked around NAM and still haven't found the exact answers I'm looking for.
I have a 2005 R53 MCS (right hand drive, Australia) that I bought with a JCW intake on it- I tried installing an Alta CAI on it today, to find that the installation instructions didn't make sense in my situation! My JCW top air box has wires coming out of it that I didn't expect to see.. any suggestions?
Pictures are below:
1. The connection at the top air box, with wiring coming out to:
2. Box A (in red), which connects to the fuse box:
3. Red wire (finger pointing to it)
My questions are:
Given that I've read that the JCW intake is a top and bottom box set, do I need to remove both and put the Alta CAI onto a stock bottom box?
Is it ok to just remove all the wiring associated with the JCW intake, including the grounding wire?
Will a JCW strut brace fit again on top of the Alta CAI (without a box lid), or does it have to be cut into?
Thanks in advance.
Attached Thumbnails Changing R53 JCW intake to Alta CAI-img_1598-copy.jpg   Changing R53 JCW intake to Alta CAI-img_1599-copy.jpg   Changing R53 JCW intake to Alta CAI-img_1605-copy.jpg
Old Jan 1, 2011 | 09:21 PM
howsoonisnow1985's Avatar
howsoonisnow1985
think they measured and controlled the Flap.
Old Jan 3, 2011 | 12:13 AM
FlzRider's Avatar
FlzRider
The top half of your JCW intake needs to be removed; you retain the bottom half. You can remove all the wiring associated with the flap electronics. Make sure you cap off the vacuum line as well. And no the strut bar will not fit without trimming the alta sheetmetal.
Old Jan 3, 2011 | 12:27 AM
vinno's Avatar
vinno
Thanks for that info- I have since done some reading and realised that I have to remove the yellow wire from the 'white/red' wire after it was spliced originally, plus remove the red wire from the fuse box. However, what do you mean by capping off the vacuum line?? My Alta CAI came with this spiggot that I'm not sure how to use... Also, you mean you can use the JCW bottom rather than the stock bottom?
Old Jan 3, 2011 | 05:55 PM
cct1's Avatar
cct1
Why are you switching it? It's more of a lateral move than an improvement.
Old Jan 4, 2011 | 09:27 AM
ntmid8r's Avatar
ntmid8r
I belive the bottom is the same for JCW or stock R53.
You have to put a small cap on the line or you will have a leak.
Also tie the line out of the way so it does not accidentally get pulled off later on.
You will only gain sound, not HP from this swap of intakes.
Old Jan 7, 2011 | 01:34 AM
vinno's Avatar
vinno
I'm not sure where I'm meant to cap it.. at the red line, blue line or yellow line? this was all I could find. Does the Alta CAI even use the vacuum unit?
Attached Thumbnails Changing R53 JCW intake to Alta CAI-jcw-intake5-copy.jpg   Changing R53 JCW intake to Alta CAI-jcw-intake6-copy.jpg
Old Jan 7, 2011 | 07:51 AM
ntmid8r's Avatar
ntmid8r
You can put a cap on the end of the indicated RED hose. Take that T fitting off and put a cap on it.
The Alta unit does not use the vacumm line.
Old Jan 7, 2011 | 05:20 PM
vinno's Avatar
vinno
Thanks for the tip. All installed now. I found that my JCW intake vacuum system probably wasn't installed the way it showed. And yes, it was the red!
Teh
Aug 22, 2022 04:37 AM
AWOL
Mar 28, 2016 10:51 AM
tr3y003
Oct 22, 2015 10:48 AM
sprp85
Aug 22, 2015 06:16 AM
