R56 Short shifter...
Old Dec 29, 2010 | 04:04 PM
automan21's Avatar
automan21
Short shifter...
I have only found NM and some other one (no name brand) of short shifter for my '11 Mini S. Anyone know of anymore? I feel like Im driving a semi with the amount of travel it has now lol.
Old Dec 29, 2010 | 04:53 PM
Porthos's Avatar
Porthos
Alta, Cravenspeed, and I think there is like 2 more.
Old Dec 29, 2010 | 05:39 PM
automan21's Avatar
automan21
Anyone have this one and how was the install?
http://www.cravenspeed.com/products/...t-Shifter.html
Old Dec 29, 2010 | 06:26 PM
Porthos's Avatar
Porthos
I have the Alta version (same thing except Cravenspeed doesn't need allen wrenches to adjust) and it is pretty straight forward. What ever you get it will most likely come with instructions.
Old Dec 29, 2010 | 07:12 PM
onefish2's Avatar
onefish2
I have the Craven Speed short shifter and well cover. Its been installed for almost 2 years now. It has always been on the lowest setting. I love it. Its one of the best mods on my car. Check my signature as you can see this is just one of many, many mods done to my car. Also click on the link to my flickr site. There are many pics of the short shifter there.
I did not do the install myself. I have a trusted mechanic do almost all of my modding work for me. He said the install was very easy.
Old Dec 29, 2010 | 07:29 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We have a few different options:
http://www.waymotorworks.com/07-10-c...rior/shifters/
Personally I recommend the Cravenspeed short shifter. It is adjustable, and has a great feel to it. Plus the adjustment is a simple ****, no screws like the other brand to have come loose.
Old Dec 29, 2010 | 09:37 PM
ammodave's Avatar
ammodave
My first mechanical change to my 2010 last spring was a "Helix" short shifter. It's cheap and all the installation is done under the car; lots of nuts and bolts to remove and replace but it wasn't too tough for even a nimrod like me. The shift **** stays at the same height but the throw from 1st to 2nd is shortened from 4" to 3" (making it the same as my old Miata).
Old Dec 30, 2010 | 05:33 AM
Tata Steva's Avatar
Tata Steva
Any truth in the statement that short shift adapter (like NM one) can in any way harm any components of transmission, clutch or anything else?
I am about to put one in and want to "get to the bottom of it"...
Old Dec 30, 2010 | 05:47 AM
C H I C K L E T's Avatar
C H I C K L E T
I love my CravenSpeed adjustable with the well cover. Its clean and perfect for me!
Old Dec 30, 2010 | 07:48 AM
onefish2's Avatar
onefish2
Just going on 2 years. No problems. I am sure others that have had short shifters on longer can chime in here.
Old Dec 30, 2010 | 09:24 AM
pheatton's Avatar
pheatton
Have the same question since I will be getting my '11 MCS here soon.
Just a few more days!!
Old Dec 30, 2010 | 03:21 PM
automan21's Avatar
automan21
Aww man, thats the best part when you do it yourself.
Thanks for the info. I will be picking up the cravenspeed one soon. I will wait till I gt my invidia exhaust so I can do all the under car stuff at once.
Old Dec 30, 2010 | 04:11 PM
Dex05S's Avatar
Dex05S
The "shorter shift" is only in the amount the stick travels. The cables still travel the same distance, as does the shift fork, in order for the gears to mesh. As far as the trans is concerned, nothing has changed. Go ahead, you'll love the shorter throws!
Old Dec 31, 2010 | 12:03 PM
Govtslug's Avatar
Govtslug
I put a Helix short shifter in a couple of months ago. The only disadvantage is that it's not adjustable. But I think it shortens the throws enough to make a noticeable difference, but not so short that it makes the shifting notchy. And, it's only $45, so much cheaper than the SSK's that require a whole new shift lever. Overall, I'm very happy with my choice.
Tom
Old Jan 1, 2011 | 11:39 AM
Speedin Bob's Avatar
Speedin Bob
NM or Helix short shifter for the win. I've had my NM for six months, drive my MINI daily, and love it. Shorter stalk in the cabin or was not a preferred option.
Easy install. Buy the 'box' that NM sells also so the linkage isn't exposed to the elements if you live in a four season part of the country.
Bob
Old Jan 1, 2011 | 01:55 PM
automan21's Avatar
automan21
where'd you guys get the Helix?
Old Jan 1, 2011 | 02:41 PM
ammodave's Avatar
ammodave
Way Motor Works per post #6 above; great folks to do business with.
Old Jan 1, 2011 | 03:32 PM
automan21's Avatar
automan21
thanks
Old Jan 1, 2011 | 04:04 PM
Speedin Bob
Bought my NM hardware and box from WayMotorWorks. Another thought is see if he will sell you just the box then you can perform the dissection of your stock shifter linkage cover. Save you some bucks if you have a Dremel and a steady hand.
GOOD mod!
Old Jan 2, 2011 | 06:06 AM
Govtslug's Avatar
Govtslug
A lot of suppliers have the Helix short shifter. You can go to Helix directly too, helix13.com I think. They seem to be the same price everywhere. I also got the NM shift linkage box, although it's pretty expensive at $89. That's probably a good idea to use this (or modify your old one). The Helix instructions say to just throw your old box away since the new linkage interferes with it, but I didn't like that idea. There's too much chance of dirt getting into the linkage. Now I've got a stock box that I have no use for. Anyone interested in buying it?
Tom
Old Jan 2, 2011 | 12:34 PM
automan21's Avatar
automan21
So which one has a shorter throw Helix or NM? And does that new fashioned box on will it interfere with the exhaust?
Old Jan 2, 2011 | 02:03 PM
Speedin Bob
NW and Helix have the same throw. Helix is cheaper. The box does not interfere with the exhaust or the heat shield.
Old Jan 2, 2011 | 02:09 PM
Govtslug's Avatar
Govtslug
+1 on what Speedin Bob said. I think the NM and Helix are exactly the same. The box only bumps out the clearance by about half an inch, so the aluminum exhaust shield bends around it easily.
Old Jan 2, 2011 | 03:23 PM
Dex05S's Avatar
Dex05S
+1 for the Helix! Works great!
Old Jan 2, 2011 | 05:20 PM
automan21's Avatar
automan21
cool, thanks everyone.
Doc Pain
Mar 10, 2021 04:50 AM
minimofo
Dec 26, 2015 12:03 PM
02miniSguy
Nov 17, 2015 10:29 PM
ToroPerro
Oct 1, 2015 12:54 PM
Samhillrocks
Sep 29, 2015 12:55 PM
