Drivetrain Anyone's engine running lean after upgrading exhaust???
Old Jan 1, 2004 | 05:35 PM
bproctor's Avatar
bproctor
I came back from a roadtrip today and had the Service Engine Soon light come on . I hooked up my scanner to the car and got a P0171 code, which is a "Lean Bank 1" code. I installed a Magnaflow exhaust about a week ago, but I can't imagine that minor upgrade causing my engine to run lean. I went up about 6000 in elevation over this short road trip so I don't know if elevation would have anything to do with it. From my experience, higher elevation makes your car run richer due to less air. I'm afraid to put my new BMP Intake on now, :???: because that will just increase the airflow even more, which will make it even leaner. Any suggestions???
Thanks,
Brent
Old Jan 1, 2004 | 10:01 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Doesn't the ECU have to adjust to your mods and learn a bit before adjusting fully. I'd say give it a little longer and see if the light keeps coming on. If so then see your dealer but don't say much about the upgrade to the exhaust. You can always say you've had that awhile. Maybe don't put on the intake until all is acting normal again.
The leaness might not have anything to do with the exhaust mod.
Old Jan 2, 2004 | 09:34 AM
kenchan's Avatar
kenchan
if it's a turbo charger the freer flowing exhaust will help compress more air
on the intake turbine contributing to some initial leaner conditions before the
ECU compensates more fuel, but I don't think it has the same effect on
superchargers. it will lessen backpressure enabling a freer flowing flow,
(similar to that of NA motors) but doesn't help as much as it helps turbo.
id just drive it as is for another 300miles and see if the cel turns off. if it
starts flashing (or you hear pings or feel lots of hesitation), take it to the dealer.
_________________
03MCS IB/Blk: 123, Aerokit, R90 17x7, TK5 16x7, 6CDMP3, and a few more.
jeffbeckhudd
Aug 29, 2015 09:11 PM
Colt45Magnus
Aug 13, 2015 11:18 AM
Aug 12, 2015 01:24 PM
Lt. Dan
Aug 10, 2015 08:23 AM
