spare wheel
Old Dec 18, 2010 | 10:43 AM
MickMini's Avatar
MickMini
spare wheel
i have decided to get rid of my runflats and get michelin pilot sport a/s. My dilemma is where do I get a spare wheel from or fix a flat maybe. Any ideas would be welcome. MCS,205/45 x 17
Old Dec 18, 2010 | 10:46 AM
Vollgas's Avatar
Vollgas
I have a full size 15" spare wheel from a R50 if your interested.
Old Dec 18, 2010 | 10:50 AM
MickMini's Avatar
MickMini
Old Dec 18, 2010 | 11:42 AM
Vollgas's Avatar
Vollgas
Yes, 1 spare tire, ready to go.
If you have BBK this tire won't fit.
Old Dec 18, 2010 | 11:54 AM
iwashmycar's Avatar
iwashmycar
I think there was just one in the marketplace...some 17" Konig with a bag and all
Old Dec 18, 2010 | 09:47 PM
MCSfanboy's Avatar
MCSfanboy
I carry a Slime kit with me to repair flats. It’s around $59 at your local Wallmart. http://bit.ly/b6cLE1
Or, you could use Tyre Guardian. It’s also suppose to work fine with modern tire pressure systems (TMPS). It works on the opposite principle of green goop like Slime. You add the liquid to your tires before you have a flat. Matter in fact, it's suppose to last the life of the tire. Here's their website for more info: http://www.tireguardian.com/ I don’t know how reliable this product is over time. I know slime works, it’s just messy.
Old Mar 24, 2011 | 06:33 AM
Redbob's Avatar
Redbob
Good morning!
I'm new here - not new to the world - and I have a couple questions along these same lines: I recently bought an '09 Clubman S JCW that has had the runflats replaced with conventional Kumhos, and I'd really like a spare to fit the rears only (if I have a flat in the front, I'll just swap wheels & tires around, put the spare on the rear).
Is there a wheel that will (a) fit over the rear brakes, and (b) mount a tire that will fit in the spare tire well?
I don't care if the tire is way undersized: it would only be a temporary measure.
Question #2: If there's not a full-size, does anyone know if the space-saver spare sold by for example Mini-Mania will fit the rear of this car?
TIA,
R
PS: OK, question #3: Opinions on a tire for long tread life? This car is mostly used for commuting/ferrying kids around/runs to the grocery, not track days or street racing.
Old Mar 24, 2011 | 06:50 AM
iwashmycar's Avatar
iwashmycar
dont Clubmans have a spare tire?
If there isnt one in the well at the moment, im sure you could just find one somewhere?
maybe my assumptions are wrong lol
Old Mar 24, 2011 | 06:54 AM
Redbob's Avatar
Redbob
Would it have had a spare tire with runflats?
And would I have asked about a spare if I had one???
Old Mar 24, 2011 | 07:22 AM
iwashmycar's Avatar
iwashmycar
Makes sense. You had asked if there is a wheel and a tire that will fit in the well. I was just thinking, Yes, the OEM one will.
I thought that they came with one regardless. Further research proves me wrong.
The space saver one should fit. I have also heard Chevy Cobalt ones work well and are more inexpensive than MINI stuff
Old Mar 24, 2011 | 07:28 AM
Redbob's Avatar
Redbob
Thanks, but no, the OEM tires (meaning the ones on the ground, right?) will not fit in the spare tire well because they're just over an inch too large in diameter. Inflated, anyway; although I have been tempted to deflate one and see if it can be crammed in there. After all, I do have that little compressor...
I've seen several threads discussing using one space-saver spare or another, but I guess my real question is whether the JCW-package has larger rear brakes than the std 'S' model, and would therefore interfere with a space-saver (or other) wheel that would otherwise fit on an MCS?
Old Mar 24, 2011 | 04:37 PM
Crashton's Avatar
Crashton
Your rear brakes are the same as ones on a MCS. A donut spare will fit over the rear brakes.
Old Mar 24, 2011 | 05:45 PM
UAL_Kingpin's Avatar
UAL_Kingpin
Originally Posted by Redbob
Good morning!
TIA,
R
Give Chad a call at Detroit Tuned
http://www.detroittuned.com/shop/
I bought a spare tire from him for my Clubman S. I don't know if he has one that will fit a JCW.
Old Mar 25, 2011 | 06:23 AM
Redbob's Avatar
Redbob
Thank you, sir!
That's the answer I needed.
Knowing that, I can go for a donut, or else try to find some other MCS-fitting wheel with a tire that goes under about 23" in diameter.
Thanks again,
- R
PS: I got the key away from wife and *I* am driving the Mini today!!!
Old Mar 25, 2011 | 06:31 AM
Redbob's Avatar
Redbob
Thanks for the tip; they have a good deal going on a space-saver spare.
Old Mar 25, 2011 | 11:13 AM
SidSwiftsteel's Avatar
SidSwiftsteel
I purchased the spare from Detroit Tuned. I've yet to put in my Clubman because I still need to find a bolt to hold it in. I also want to figure out a way to keep the Styrofoam insert that fits in the spare wheel well. Oh, my clubman didn't come with a jack so I need one of those as well!
Old Mar 25, 2011 | 09:09 PM
UAL_Kingpin
Foam tray and bolt part numbers:
71106778759 Trunk tray, emergency wheel
36106782325 Mounting screw, spare wheel (M8X56)
36106781466 Spare wheel retainer
Got that information here
https://www.northamericanmotoring.co...609-post9.html
Pictures of install here
https://www.northamericanmotoring.co...78-post15.html
You can buy these parts from Pelican Parts
http://www.pelicanparts.com/euro/cgi...r&Input_Make=Y
kazyn
Oct 25, 2019 02:34 PM
TJANK
Aug 24, 2015 06:11 PM
blackie
Aug 23, 2015 08:44 PM
Mrdi
Aug 7, 2015 01:06 PM
