Suspension Things I learned while installing TSW springs and Koni sports.
Old Nov 14, 2010 | 10:58 AM
richardsperry's Avatar
richardsperry
I just finished installing TSW springs, Koni sport shocks, and a 19mm Hotchkis rear bar.
The bar install is pretty easy, but I've got a lift and air tools. Just make sure that the hole in the bushing for grease is actually open. Otherwise the darn grease just doesn't want to go in there...lol
You have to drill out the rear spring hats, and washers from 10mm to 12mm because the shaft of the Koni is... well 2mm bigger...lol
Well what it like? I couldn't have believed it. It rides like an entirely different car. It's way more compliant over any sharp bump.
Virtually eliminated squat and dive, and torque steer! Far less body roll.
I wouldn't have thought it was possible by just changing shocks and springs.
Highly recommend it.
Old Nov 14, 2010 | 11:43 AM
old81's Avatar
old81
M6
Congrats on your install. Where did you source the Koni Sports?
Did the Koni instructions tell you that you had to open up the hats?
Pictures?
Glad you like it. And how many miles are on your MINI?
Don
Old Nov 14, 2010 | 02:08 PM
richardsperry
I picked them up from the marketplace used.
The Koni instruction might as well be Egyptian hieroglyphics. (or maybe Ikea...) They are completely useless except for the torque requirement for the nuts. It was pretty obvious that the shaft was bigger. I just measured the shaft with a micrometer and made it fit. Other than that, they are just like stock. I only had to drill the hats for the rears. the fronts fit fine.
Pictures? no... I didn't bother.
My 2010 MCS has just over 9500 miles.
Old Nov 14, 2010 | 08:42 PM
dunphyj's Avatar
dunphyj
came across the shaft issue with my Koni based coilovers :P fun stuff hahahah
Old Nov 17, 2010 | 03:05 PM
old81's Avatar
old81
M6
Thanks for the commentary.
How do they feel after a few days of motoring, have you done any aggressive drives?
Don
Old Nov 17, 2010 | 04:03 PM
fjork_duf's Avatar
fjork_duf
Did you have to purchase the bushings to attach the rears to the aluminum swing arms?
Old Nov 17, 2010 | 04:54 PM
richardsperry
No bushing required. they are part of the rear shocks.
The car really is transformed. The ride it worlds better. No squat or dive. Compliant over bumps. I might add a bit more rebound damping and see how that works, but full soft was a very good starting point. Maybe a touch more rear bar too.
Old Dec 3, 2010 | 06:48 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Ok, so almost 3 weeks later are you still loving the TSW springs?
Old Dec 4, 2010 | 05:14 AM
richardsperry
Yes. Paired with Koni's the car is great.
Oh and Way, sorry I didn't get back to you about the end links. Well, they do fit, just barely...Just about 1 thread exposed past the nut on the lower mount. I guess I just had it cocked a little bit the first time. But, the stock lower stud is 10mm longer than the top... If you want, I'll send it to you to check for yourself.
Old Dec 4, 2010 | 06:21 PM
etalj's Avatar
etalj
Yes, the powergrid's don't come with the extra long thread at the top, so I just didn't use the washer, to make the effective length longer.
W0TM8
Dec 19, 2019 07:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Emnotek
Aug 13, 2015 05:47 PM
minipopkart
Aug 13, 2015 05:22 AM
