Hello! Fairly new owner of 2004 MCS 40
Old Nov 10, 2010 | 06:42 AM
tyrobert's Avatar
tyrobert
I have a 2004 MCS 40 & the passenger window does not go down. I have done some research on the web & have tried the simple stuff to fix this temp. & buy yourslef a little more time. However, I am now at a point where I want to try the repair myself for the Mini Dealer wants 4 hours of labor @ 100 per hour plus the parts. If this repair has been documented by anyone in the past I would appreciate it if some one could pass it along.
Thanks,
Ty
Aberdeen, MD
Old Nov 10, 2010 | 07:51 AM
DAVESTER's Avatar
DAVESTER
Have you tried the "Fonzie Method" to kick start your window? I too have an '04 and my pass. window refuses to go down from time to time. Simply make a fist and give your door a whack or two above the lower speaker on the door.
Give it a try before replacing the motor assembly.
Old Nov 10, 2010 | 08:06 AM
tyrobert's Avatar
tyrobert
Dave, hi! yes I have done this as I informally noed I have tried the short term fixes for this & they do not work anymore. Thus I am quite sure I will need to buy the new motor & regulator as I believe they are sep. items. Recommendations I have seen say that if you tear the door apart replace both components.
Say where are you located? Your Mini looks pretty sharp. Do your mods. equate to a Stage 2 or Stage 3 Upgrade Kit? I have a Stage 2 Kit on mine. Suppose to push about 220 HP, but I have not had it on a Dino to confirm (second owner). Ty
Old Nov 10, 2010 | 11:01 AM
BensMini's Avatar
BensMini
Welcome to the forum, yes it soundsa like some new parts will be required. I've never done this on a MINI, but did on my Camaro and its a real PITA.
Old Nov 10, 2010 | 01:40 PM
canucc00's Avatar
canucc00
You can do it your self and save, it's not that hard just your time. Get the part from dealer or on line, google window regulator 2004 mini. There was a how to on this site here is the link. http://wiki.answers.com/Q/How_to_ins...ulator_install
Spank
11
Apr 9, 2020 02:23 PM
brother i
Tires, Wheels, & Brakes
Aug 23, 2015 01:15 PM
keck.j
Aug 18, 2015 08:18 PM
minipopkart
Aug 13, 2015 05:22 AM
PrimePower
Aug 11, 2015 12:51 PM
