R50/53 Tailight replacement.
Old Nov 2, 2010 | 12:20 PM
gpsmbear's Avatar
gpsmbear
Hello everyone,
I'm a new member and a new owner of a not-new(2005) Mini Cooper Hatchback.
The other day, while loading something into the boot, I bumped the object against the thin plastic cover of the left rear light complex, producing a nasty-looking star crack. Since that is the only ding on my car, I could not resist trying to mend it. A first attempt using super glue was unsatisfactory, possibly because I used the gel form instead of the liquid.
I sprung for a new assembly. Accessing the old assembly through the panel cover on the side of the boot was easy, as was removal of the single washer/nut at its forward end. The assembly still won't move, however. I notice the two shiny metal clips on the new one. I can see them on the old one, but they are quite inaccessible and I can't see whether and/or how they attach. Can someone help? It looks like I'll need to do this again to change burned-out bulbs.
Old Nov 2, 2010 | 12:35 PM
JustinGTP's Avatar
JustinGTP
IIRC, there are two nuts, one up top and one at the bottom. I'll run out and check my MINI in a few (2005 also) and confirm for you.
Old Nov 3, 2010 | 03:54 PM
gpsmbear's Avatar
gpsmbear
Thanks much for your most prompt reply . I'm looking at the replacement assembly now. I only see one threaded bolt. It's in the middle, towards the inside. I think those two shiny clips toward the outside may have something to do with holding the unit in place, but I can't see how they work, or how to unsnap them.
Old Nov 3, 2010 | 04:16 PM
Mondo's Avatar
Mondo
This might help
https://www.northamericanmotoring.co...ight-bulb.html
Old Nov 4, 2010 | 10:35 PM
JustinGTP's Avatar
JustinGTP
excellent mondo thanks for putting that up. and yes only one bolt gpsmbear, not two!
Eric Campbell
35
Oct 27, 2020 08:31 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
daviday
Sep 25, 2015 01:31 AM
nealsmini
Sep 24, 2015 01:14 PM
