lowering and 18" wheels
Old Oct 23, 2010 | 08:25 AM
charliebrown33's Avatar
charliebrown33
I just bought a 2007 mini cooper s . I was wondering what would be a good lowering kit to put on the car and also what size 18 " wheels and tires to use once the kit is on ?
Thx........
Old Oct 23, 2010 | 08:32 AM
ZippyNH's Avatar
ZippyNH
Properly sized wheels are all the same diameter (more or less) to keep your gear ratio's and spedo correct. So as long as you stick with a "recommended" size, the usual kits will work fine. If you fall in love with a rim with the wrong offset, then you migh need spacers to make them work...same for tires... Too tall sidwall, or too wide might need spacers to get you clearance.
Good luck.. Sorry about the lack of specfic info, but somebody should chime in, or do a search!!
Old Oct 23, 2010 | 08:42 AM
charliebrown33
Thx for the info.
Old Oct 23, 2010 | 10:33 AM
Creeve's Avatar
Creeve
how much lower do you want to go? There are parts that will lower the car .75" others that can drop it 4" and everything in between.
Old Oct 23, 2010 | 11:19 AM
charliebrown33
lowering
I would like something adjustable so i can play.
Thx...
Old Oct 23, 2010 | 01:41 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Thx...
To lower your MINI you will need adjustable coilovers. Then you can pick any ride height from a little lower than stock to about a 2" drop but that would invite rubbing- the slammed look.
18" wheels are not a problem if you can use 7 to 8" wide rims and a tire diameter of about 24.4" or less down to about 23.9" is fine. Tire width about 205 to 235mm usually works OK.
If you need more negative camber then you will need camber plates in front either fixed or adjustable and rear lower adjustable control arms.
You have to install the coilovers with the ride height you want, any camber plates and control arms before you do alignment. Any additional upgrades to endlinks or swaybars does not affect ride height or alignment so can be done anytime.
Realize that larger 18" wheels often mean lower profile tires which are harsher riding depending on which tire you choose with runflats being very stiff. They are also more prone to damage when hitting a pothole or bump in the road so if you have good roads it should be fine. If not go slow.
Old Oct 23, 2010 | 07:08 PM
charliebrown33
Thx allot, you gave me all the info I needed..
Old Oct 26, 2010 | 04:12 PM
MINNNI
I had my 2007 MCS cabriolet lowered w/ Eibach springs and no camber adjust.The ride is stiffer than the stock sport springs, as expected
Old Oct 26, 2010 | 07:00 PM
charliebrown33
Thak's for the info...
theblackfalcon
Oct 11, 2015 09:49 AM
Aug 21, 2015 11:25 AM
Minibeagle
Aug 13, 2015 10:00 AM
nomar116
Aug 12, 2015 05:24 PM
