R50/53 Showing my r53 some love...
Busy week for the mini , new rear brakes , oil change , new thermostat and gasket , brake and clutch flush , gear box oil change , 4 new conti extreme contact dws (bye bye run flats) and the score of the week a spare doughnut for free ... And next week the chrome trim black out will commence .... This mini sure is keeping me busy but I'm loving it ...
How long did it take you to bleed the slave cylinder? Any problems? I saw a great DIY video on YouTube for this job. I'll be doing it soon also.
You should post some pics after the blackout.
Good job on your MINI TLC!
Chad
Chad
It was quick using a pressure bleeder , just remove the front engine cover and the slave cylinder is right there, just FYI the slave bleed screw is not like a brake caliper bleed screw , you have to loosen it about 3 full turns to allow fluid to flow out , with a pressure bleeder the brake and clutch flush took all of about 5 mins , although having a lift at my disposal makes every job easyer .
Black out started , tints :35% front 20% rear and boot glass , mirrors plasti dipped , beltline taped using 3m strpe tape...to be continued....ps , i just serviced the carrera gt in the pic...
Drivetrain Won't hold idle after work performed
Lt. Dan
Aug 10, 2015 08:23 AM
Aug 7, 2015 09:51 AM
Navigation & Audio Steering wheel controls for music
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
I bet the v10 in that Gt wasnt too different from working on the MINI's 4 cyl.
