Sun Visor mirror door
Old Oct 3, 2010 | 12:47 PM
MiniKar's Avatar
MiniKar
Any thoughts out there on how to fix the little door that covers the mirror ?
Mine won't stay open and it has to be held open to use the mirror.
New visors are $ 80-90 so any repair thoughts would be helpful. . . . . . . . .
( 2006 MCS, passenger side )
Old Oct 3, 2010 | 01:00 PM
Bilbo-Baggins's Avatar
Bilbo-Baggins
I had to replace mine for the same thing. Not sure of any fix.
Old Oct 4, 2010 | 12:17 PM
gldnpwz's Avatar
gldnpwz
I had the same exact problem on our 2006 MCS just a few months ago. The dealer replaced the complete visor/morror assembly under warranty.
Old Oct 4, 2010 | 03:02 PM
SteveB625's Avatar
SteveB625
I fixed mine. Had to remove he mirror from the visor. I left the wires connected. There are 2 little metal clips at the top hinge. The plastic breaks and they back out. If you loose the metal clip you could be out of luck.
The fix is to carefully press the clips back into position and epoxy them in place. I used some masking tape to keep tension off the wires while the epoxy dried.
In order to hold the mirror in the visor I cut away some of the hidden material to gain access to the plastic base. I then attached some high strength velcro to the visor and mirror then pressed it into place.
That was on the drivers side visor and now the pass side is droopy so I will be fixing that one next.
Hope this helps.
Old Oct 5, 2010 | 10:03 AM
nervous's Avatar
nervous
I have an '06 S with about 40k miles - my passenger side vanity mirror door was broken-off - dealer fixed it for free - said it was under warranty.
potterstein
Dec 30, 2024 05:18 PM
Filmy
Sep 7, 2015 08:27 PM
potterstein
Sep 4, 2015 09:52 AM
Sep 3, 2015 10:45 AM
Ntety
Sep 2, 2015 08:39 PM
