Low tire air pressure light and Warranty
Hey Guys,
I recently had low tire air pressure light on a couple of times - it went off after putting some air. (It is why I suspected there's some leakage on my tire(s))
Will my warranty cover this issue?
Thanks in advance!
PROUD TO BE SMALL!
Thanks in advance!
PROUD TO BE SMALL!
generally tires are not covered under warranty (or MINI pre-paid maintenance) unless you bought extra coverage.
In order to properly respond we usually need more details including what year and model is your MINI at a minimum . . .
have you looked for a nail in the tire(s) in question?
Fill all 4 tires to exactly the same amount of pressure, then reset. Next time the light comes on then carefully measure all 4 tires again to find the leaking tire(s).
My TPMS light came on today and I found all 4 tires at 27.5 PSI. I filled them back up to 38 PSI.
Another time the light came on I actually had a nail in one tire but it was only at about 3 PSI less than the others.
If TPMS system is not working correctly then that is a warranty item.
If a tire does not hold air then that is not usually a warranty item from MINI unless you bought the extra policy.
Quick question. I keep seeing on this site people indicating that they are putting 38psi in their tires. I have a 2010 MCS and thought that the chart on the door states 33psi unless if you are exceeding 100mph. As much as I would like to 100mph on a daily basis, not gonna happen. 38psi seems like an awful high tire pressure......
My tire pressure light came on recently, too. I simply called my dealer and asked if they could reset it. They checked my tire pressure, added a touch of air, and had me in and out in about 10 minutes and did not charge me for anything.
many owners are an hour, or hours from their dealer
BUT - dealer adjusted your tire pressure
you must be what some would call a trophy wife
My dealer(s) would laugh me out of the shop for that request
Seams like I fill the tires more often on my MINI especially after a long trip but I have never had a car with TPMS. So this time I put in a bit more.
Dec 23, 2015 10:36 AM
phrza81
Oct 10, 2015 11:37 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
