Navigation & Audio blown speaker
Old Sep 19, 2010 | 03:40 PM
freeskier's Avatar
freeskier
blown speaker
i have a blown speaker in my passenger side door, since its gone anyways where do you suggest i look for replacements
Old Sep 19, 2010 | 04:00 PM
ellcapitan's Avatar
ellcapitan
Nowhere in your longwinded signature did I see any mention of which factory audio system you have. If it's the HK, and assuming you're not into replacing the whole system, I'd definitely go with a stock replacement speaker, due to the oddball impedance requirements. If it's the base-version non-HK, you do have aftermarket replacement speaker options, but none of them will yield much, if any, improvement unless you, once again--you guessed it--replaced the whole system.
To sum it up, if it were me...and I'm still running with the assumption that you're not interested and/or prepared to do a major sound system overhaul...either way, I'd simply replace the bad speaker with a used stock replacement, off fleaBay and be done with it.
Old Sep 19, 2010 | 05:56 PM
freeskier's Avatar
freeskier
i believe its a base system, i am not a sound guy i barly ever use the radio. would an aftermarket unit be cheaper?
Old Sep 19, 2010 | 06:02 PM
CRoth's Avatar
CRoth
I'm dealing with the same issue but mine is an HK system. My right door speaker only distorts after it's been playing a while. I'm thinking my problem may be related to the amplifier.
I'm not trying to hijack your thread. I just had to hop on here due to the similarities.
Old Sep 19, 2010 | 07:00 PM
freeskier's Avatar
freeskier
more than welcome. mine crackles and fuzzes unless the volume is switched tword the drivers side and quiet. also, i have to remove the driver side door panel to fix the handle anyways, should i replace that speaker also because it has had to pick up the slack from the passenger side unit?
Old Sep 20, 2010 | 01:46 AM
CRoth's Avatar
CRoth
I like to do everything myself but when it comes to wiring I'm not that great. I'm also color blind, lol. I'm going to a local car audio place today to see what they think. I'll post my findings later tonight.
Old Sep 20, 2010 | 05:42 PM
ellcapitan's Avatar
ellcapitan
You still should replace the bad speaker with a stock one...whether it be new ($$) or used, because any aftermarket one you get will not have the same specs, as far as sensitivity rating, minimum power rating (yes that's right, MINIMUM power rating would actually be a replacement speaker consideration in the MINI's dreadfully underpowered standard audio system), not to mention actual sound properties...as the stock speakers.
If you don't want to hunt down a used stock speaker (or pony up for a new one), at very least you should replace both front speakers as a pair with aftermarket units made for low power applications (the good news is that these are also usually the cheapest, and most likely to actually fit, depth-wise).
Old Sep 20, 2010 | 07:54 PM
freeskier's Avatar
freeskier
ok, well if i cant find any used i will look aftermarket, does anybody have any suggestions as to what fits/whats cheap/ what i can use to get a little more volume? thanks
scottselk
Jul 20, 2019 06:43 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
vulkandino
Oct 31, 2015 08:29 PM
patsum
Oct 1, 2015 06:33 AM
silence2-38554
Sep 28, 2015 12:19 PM
