Suspension Rear suspension rattle after KONI FSD install
Old Sep 16, 2010 | 06:33 AM
stevendoll's Avatar
stevendoll
After installation of Koni FSD's I developed rattle in rear of car. Seems to come from both sides in the rear of car in wheel wells over choppy roads. I had them re-installed with new strut top mounts to no avail. Perhaps somewhat better, but worsened over time. Is there a manufacturing issue that changes the tolerance of the top of strut to the mounts to cause rattle? Thoughts...
Old Sep 16, 2010 | 06:42 AM
malteseracer's Avatar
malteseracer
Are you sure it's the struts rating and not something you disconnected? How does it handle??
Old Sep 16, 2010 | 07:34 AM
stevendoll's Avatar
stevendoll
Handles great. No other complaints. I took everything apart again, no parts are missing, there is a no obvious source of excessive play.
Old Sep 28, 2010 | 11:45 PM
KC Jr 54's Avatar
KC Jr 54
My immediate thoughts are your sway bar endlinks. Double check their tightness. Are the endlinks stock ?
Old Oct 5, 2010 | 08:37 AM
PenelopeG3's Avatar
PenelopeG3
Sometimes the big nut at the top of the shock loosens up. I had to re-tighten mine twice.
Old Feb 16, 2011 | 06:07 PM
stevendoll's Avatar
stevendoll
car has now been to 4th place with no diagnosis. Currently at dealer. apparently, the shocks were replaced with another cars, and it still made noise. Not endlinks- were removed and still rattle. Any other thoughts? Cold loose muffler baffles give this effect?
Old Feb 16, 2011 | 07:58 PM
wzabrouski's Avatar
wzabrouski
I had something similar once and it turned out being the rear sway bar bushings being worn down and the sway bar hitting.
Old Feb 19, 2011 | 07:28 AM
tomcar's Avatar
tomcar
Did you ever get to the bottom of this?
Old Feb 19, 2011 | 11:07 AM
stevendoll's Avatar
stevendoll
No, I did not. The car was tested with sway bar disconnected, still a noise. The project was getting too expensive for me, so I gave up. The struts were swapped out for stock- noise still there. So, it looks like perhaps it is the control arm bushings somehow?
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
squawSkiBum
Oct 2, 2015 09:21 AM
Emnotek
Aug 13, 2015 05:47 PM
