Suspension Bump Stops
Old Sep 11, 2010 | 04:08 PM
Driv3r's Avatar
Driv3r
Bump Stops
If i trim my bump stops will this lower the car more?
Old Sep 11, 2010 | 04:28 PM
CRoth's Avatar
CRoth
If you're using stock springs, no. With some aftermarket lowering springs it is necessary to give you the needed travel. I'm pretty sure the front bump stops are the only ones that need to be cut. I cut my front ones with my H&R springs.
Old Sep 12, 2010 | 12:40 AM
Driv3r's Avatar
Driv3r
Im using aftermarket springs. When u cut your front bump stops on h&r springs how much more did it lower the car?
Old Sep 12, 2010 | 10:03 AM
Eric_Rowland's Avatar
Eric_Rowland
It will - while going over bumps.
Unless the car is resting on the bump stops, cutting them will not lower the resting height. As CRoth said, lower springs call for cutting the bump stops to provide more travel for the shock.
Old Sep 12, 2010 | 12:43 PM
MINI33342's Avatar
MINI33342
Bump stops are used to cushion the ride if you bottom out the strut/springs. They have nothing to do with ride height.
Old Sep 12, 2010 | 08:50 PM
andyroo's Avatar
andyroo
I think many of the springs out there do actually put the car on the bumpstops at rest (which is why I'd never run them on my car).
Bumpstops are soft at first and ramp up the more they are compressed, so the change in ride height might be minimal.
- Andrew
FatherG
Oct 3, 2015 05:06 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
M7Speed
Oct 1, 2015 07:05 AM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
