Suspension How can I lower the front?
Old Sep 10, 2010 | 06:40 AM
Driv3r's Avatar
Driv3r
I just installed H&R springs in my mini, the rears look great but the front is bothering me that it has a gap as the rears has no gap at all. How can I lower my front end slightly more??
Old Sep 10, 2010 | 07:32 AM
checkmate2006's Avatar
checkmate2006
No way to lower it more with just springs. You should have gotten coilovers
Old Sep 10, 2010 | 08:12 AM
Driv3r's Avatar
Driv3r
cutting the springs ???
Old Sep 10, 2010 | 08:42 AM
spinned's Avatar
spinned
H&R coil-overs will bring it down to the ground
Old Sep 13, 2010 | 07:03 AM
Mini SUV's Avatar
Mini SUV
My TSW springs show a larger gap in the front also. There was a thread a little while back about someone that grinded a little metal off the stock front shock tab so that it would sit lower in it's wheel housing clamp. I believe it lowered his front about 1/4 inch.
Old Sep 13, 2010 | 07:42 AM
CRoth's Avatar
CRoth
The thread you're speaking about was by me. I have H&R's and had the same problem. I don't have time to post the entire process now but I will return later to help you. You simply have to trim the bottm of the bracket that holds your ABS line and brake hose on both front shocks. This will allow tge shock to sit lower in the control arm. I did this twice and got an additional 1/2" lower. No problems at all. Measure once, measure twice and be sure to make it all level.
PM me if you have any questions.
Chad
Old Sep 13, 2010 | 10:48 AM
RedSkunk's Avatar
RedSkunk
How about larger diameter wheel and tire combo up front, or smaller diameter in rear?
Old Sep 13, 2010 | 02:28 PM
CRoth's Avatar
CRoth
Here's the thread I posted previously on this subject;
https://www.northamericanmotoring.co...front-end.html
I can barely fit the tip of one finger in between the tire and wheel arch on all four corners. Everything is even all around.
Again, PM me if you have any questions.
Aug 21, 2015 12:58 PM
Aug 19, 2015 12:51 PM
FLYM1N1
Aug 15, 2015 11:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
