15" rims - no good tires for them?
Old Aug 25, 2010 | 02:52 PM
Yazon's Avatar
Yazon
Hey guys,
I need some help as the lack of good options is driving me mad. I would like to get a ultra high/max/high performance summer tire for the non S mini that we have and not change the rims.
Right now we have OEM 175/65/15 and I've searched all over the place (including this site) and the most recommended sizes are
185/65/15
195/60/15
205/55/15
Well, the last one is simply too big and each tire would be about 5lbs over the current set. Having 10lbs of extra weight on front/driving wheels is going to be noticeable on MPG, acceleration and steering.
So i would like to stay with the two smaller sizes, but i can't find a performance summer tire that isn't bad.
In 195/60/15 Yokohama AVS ES100 doesn't get glowing reviews since it gets very noisy and having a convertible which is not all that quite already would make it too much.
In 185/65/15 there no summer performance tires that i could find.
Is it really that bad for us 15" wheel Mini owners?
Anyone knows of a performance tire in those sizes?
Old Aug 25, 2010 | 04:54 PM
hsautocrosser's Avatar
hsautocrosser
195/55-15 is only 1/2" smaller in diameter than 175/65-15. A worn tire 175/65 accounts for that much difference. And you get a bit better gearing out of the deal to help with the increased weight and rolling resistance.
In any event, I think you will eventually have to stop nitpicking the imperfection of various summer tires or pay for Michelin Pilot Exalto PE2's. Look up the complaints about your current tire and see if you think the reviews are reasonable.
Old Aug 25, 2010 | 05:11 PM
ron-s mini's Avatar
ron-s mini
I have 205/50/15 Bridgestone Potenza RE-11s and really like them -- the smaller diameter gives the "just a cooper" a nice "gear" boost and lots a "grip".
Old Aug 25, 2010 | 05:14 PM
gasmini03's Avatar
gasmini03
We are using Goodyear Assurance 195/60R15 tires on ours and they still look and handle great on the road. So far we only have about 38,000 miles on them but they still have a lot of tread life left in them.
Old Aug 25, 2010 | 05:22 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I highly recommend Nokian V tires. They are the best tire you can get in 195/60/15. I'll never buy any other brand tire again for my 15"s.
You can read about them here.
http://www.nokiantires.com/tyre?id=1...&name=Nokian+V
Steering response and dry traction are excellent. They are quiet, low rolling resistance, and they hold the road well if you know how to build grip in them. They can take Autocross, and cross country trips. Mine even took 8+ full bore runs of the Dragon. These tires really come into their own with about 5mm of tread left, when all the extra cuts in the tread wear out - essentially making them Nokian Zs.
Old Aug 25, 2010 | 05:29 PM
DanF's Avatar
DanF
Along with the RE-11s you could also look at Yokohama AD08 and Dunlop Dirrezza's, both come in 205/50/15s. There are lots of good 15" tire choices.
Old Aug 25, 2010 | 05:38 PM
hsautocrosser
Dunlop Direzzas are not in that category unless they have the Star Spec compound.
Old Aug 25, 2010 | 05:58 PM
cmt52663's Avatar
cmt52663
Dunlop Direzza Star Spec 195/55-15
highly recommended for spirited driving
i earned a regional championship jacket with them in STX, and still got 20k road miles as well
i am now running the 205/50-15 ...
either the re-11 or the dunlop is the choice for stick on 15s
cheers,
charlie
Old Aug 25, 2010 | 10:04 PM
BensMini's Avatar
BensMini
I run Falken Azenis 615 205/50/15 that stick a like glue, have yet to hear a squeal no matter how hard I push it in a curve.
Old Aug 26, 2010 | 01:30 AM
agondokusumo's Avatar
agondokusumo
Im using Kumho KU31 205/55/15. They grip the road and quiet as well. I don't know what's the name in North America though.
Old Aug 26, 2010 | 03:02 AM
DOT191's Avatar
DOT191
We are running Cooper 185/60R15 on our MC. Like the ride,handling & they are quiet
Old Aug 26, 2010 | 08:02 AM
rjtrout2000's Avatar
rjtrout2000
I had the Kumho ASX in 195/55/15 and it gripped well and I had complaints about the tire, even in light snow or freezing cold temperatures.
Old Aug 27, 2010 | 09:44 AM
Yazon's Avatar
Yazon
I don't get why two tire shops (including TireRack) tell me not to put 195/55/15 if people have no issues with that tire size.
Old Aug 27, 2010 | 08:56 PM
hsautocrosser
Because there are people who forget or ignore the warning to put the same diameter tires on all four wheels. So they play it safe by recommending only the diameters used by the manufacturer. Mixing significantly different diameters can defeat abs and traction control, leading to big law suits, warranted or not.
Did TireRack really tell you to not put a set of 4 195/55-15's on a Cooper, or did they simply not suggest it as an option?
Old Aug 27, 2010 | 10:07 PM
ron-s mini's Avatar
ron-s mini
I purchased my 205/50/15s from Alex at Tire Rack -- this is even a more radical change than 195/55/15 --
Old Aug 27, 2010 | 11:29 PM
Yazon's Avatar
Yazon
They said the tire was "too small" for mini cooper, but didn't go into how that would manifest itself. So it seemed more like a caution and not a definite "don't"
Old Aug 28, 2010 | 05:22 AM
ron-s mini's Avatar
ron-s mini
Call and talk to Alex -- very knowledgeable and can explain the pros and cons of each size.
Old Aug 28, 2010 | 08:53 AM
hsautocrosser
Good advice. Alex knows his stuff and is a straight shooter.
Old Aug 30, 2010 | 03:34 AM
howsoonisnow1985's Avatar
howsoonisnow1985
195/55-15 for oem wheels.
Kimolaoha
Dec 5, 2020 09:32 PM
FLYM1N1
Oct 13, 2015 04:33 PM
gmonde
Sep 8, 2015 06:37 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
nomar116
Aug 9, 2015 09:42 AM
