Rotors warped
Old Aug 24, 2010 | 12:33 PM
ninjamini's Avatar
ninjamini
Rotors warped
My rotors are warped. I now get a vibration under braking on the highway. The brakes and roters were put on in December. I used EBC rotors.
Can I just turn the rotors or do I need to replace them?
Old Aug 24, 2010 | 01:08 PM
Capt_bj's Avatar
Capt_bj
if they are that new I'd guess you could turn them but I'd check the run-out first to see if that is really the problem
Old Aug 24, 2010 | 01:16 PM
Bigprfed22's Avatar
Bigprfed22
Have to check the run out, then make sure they have enough material to shave off. If you have enough to shave off then you'll be ok, if not scrap em and get others.
Old Aug 24, 2010 | 01:50 PM
Crashton's Avatar
Crashton
Man either those rotors are junk or you are very hard on your brakes.
You may be able to turn the rotors & eliminate the pulsing. By doing so you make the rotors thinner & more likely to warp again. Live with it of buy new rotors is my .02.
Old Aug 24, 2010 | 02:20 PM
Capt_bj's Avatar
Capt_bj
minimum thickness is stamped on the rotor soooooo . . .
Old Aug 24, 2010 | 02:28 PM
Bigprfed22's Avatar
Bigprfed22
Old Aug 24, 2010 | 08:58 PM
Calz's Avatar
Calz
I have only seen one set of rotors warp on Mini and thats on a JCW from the track. OEM rotors are very strong and resistent to warpage
Old Aug 24, 2010 | 09:11 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Have the rotor runout checked to be sure that is the problem, If it is and you cut them thinner its going to happen again and sooner. With taking off more material the rotor will be likely to warp again. That's why we use the zimmerman rotors, they work well and are affordable, along with we've never had them warp.
FatherG
Oct 3, 2015 05:06 PM
Colt45Magnus
Oct 1, 2015 04:08 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
M7Speed
Oct 1, 2015 07:05 AM
