Windsheild washer has stopped spraying.
Old Aug 10, 2010 | 04:40 AM
City of Glass's Avatar
City of Glass
Hello everyone,
Just the other day i went to wash my windshwild down, and there was no spray.
I can hear the pump run, but nothing comes out. The same goes for my rear system.
Has anyone has any experience with this issue and where I would start in identifying the issue?
Old Aug 10, 2010 | 04:50 AM
ZippyNH's Avatar
ZippyNH
The front and the rear use different tanks, different pumps, and different hoses.....
The fact you are saying they both stopped working at the same time is odd....
Make sure both tanks are full....The tanks are pretty small, and drowning on the year, will not have a warning light if low.
Then some folks find the nozzles get plugged....
So you can use a pin to clear them out...if this is the case, it helps with the windshield if you unplug the nozzle and push the gunk out the back side....then reassemble...
Do you have headlight washers? Do those still work?
Old Aug 10, 2010 | 04:52 AM
Capt_bj's Avatar
Capt_bj
assuming you have juice in the tank and checked that isn't just clogged nozzles I've heard of the hose getting dislodged from the tank/pump. You know where the filler is right? I believe the tank can be accessed by removing the wheel well liner on that side....
According the the Haynes manual description of the system and the wiring diagrams there are two relays but they connect to one pump on one tank. I no longer have a GEN1 to verify however. (Haynes chapter 12)
Old Aug 10, 2010 | 06:34 AM
City of Glass
Ok, solved one issue but created another. The rear nozzle was clogged and the water line to the driver headlight was not clamped down.
Everything sprays now. However, the windshield wipers no longer move. I have checked the fuses. WTF happened?
Old Aug 10, 2010 | 07:03 AM
City of Glass
Just attempted the ground fix, and nothing. I can hear the relay throw, but nothing. I'm going to go get some larger wire and two eyelet terminals, and try again.
Thankfully, I have a warranty on the car. Unfortunately, the local dealership usually is booked up for two weeks, its over an hour away, there is a $100 deductible, and it is Louisiana in the fall (it rains several times a week.)
Grrrr.
Old Aug 10, 2010 | 07:35 AM
City of Glass
Well, a rebuilt motor is going to run my $90 with shipping. I'm just going to take it to the dealership and let them take care of it. I think $10 for my time is worth it. Lol. Thank's for yall's help in getting my nozzles spraying though!
Old Aug 10, 2010 | 08:45 AM
uconnhuskiesfans's Avatar
uconnhuskiesfans
where is the tank for the rear wiper?
Old Aug 10, 2010 | 09:41 AM
cristo's Avatar
cristo
Alliance Member
My gen 1 MC (standard headlights) has but one washer tank which fills from
above the passenger wheel well under the hood.
Old Aug 10, 2010 | 11:01 AM
City of Glass
@uconn
I have two tanks, one on each side. The driver side tank supplies the front and rear wind sheild nozzles, while the passenger supplies the headlight washers.
Old Aug 10, 2010 | 01:43 PM
Capt_bj's Avatar
Capt_bj
Originally Posted by City of Glass
@uconn
yep - that what the haynes says (and what I remember from my 02)
window front and rear is one system while the headlamp washer (present only with xeons) is sep'rate
Old Aug 10, 2010 | 01:46 PM
NightFlyR's Avatar
NightFlyR
@uconn
+ 1 same on my 04 mcs
Old Aug 10, 2010 | 01:50 PM
Capt_bj's Avatar
Capt_bj
Had a similar problem a few years ago - after playing around under the bonnet the wipers went flaky ran real slow for a sweep then stopped. Could hear the relay but no go. Got all panicky and was checking all kinds of wiring options and pricing motors.
Finally looked under the bonnet at the linkage and found a wayward screw driver that had managed to get physically wedged in the system. Removed screw driver and everything worked fine.
Airplane mechanics in the service must account for every tool and every rag b4 closing up the airplane and signing off on the job - almost like a surgeon.
Start simple .... look for a physical blockage.
Old Aug 10, 2010 | 03:32 PM
uconnhuskiesfans
ahhh, i dont have xenons nor headlamp washers which must be why i only have one tank
Old Aug 10, 2010 | 05:44 PM
ZippyNH's Avatar
ZippyNH
On my 05' S one tank is the Xenon's+front windshield, the other is the back.
I'm pretty sure....
Old Aug 10, 2010 | 06:12 PM
Tom D's Avatar
Tom D
https://www.northamericanmotoring.co...her-fault.html
This thread might shed some light on your problem.
Old Aug 11, 2010 | 02:27 AM
City of Glass
Thanks Tom. I was able to get everything spraying after a few minutes this morning. Fixed one things and broke another. It looks like the motor on the front wipers burned up.
FatherG
Oct 3, 2015 05:06 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
M7Speed
Oct 1, 2015 07:05 AM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
