Blower Motor Woes
Old Aug 8, 2010 | 05:51 PM
DAVESTER's Avatar
DAVESTER
Blower Motor Woes
My 04S fan blower motor is making a terrible noise when the fan is on . It definitely is the blower motor bearing. Anyone ever replaced the motor or know of a how-to? Thanks for looking---
Old Aug 9, 2010 | 07:00 AM
ninjamini's Avatar
ninjamini
My 05 is in the shop now for the same issue. They say dont use it as it can blow the water pump and overheat the engine. The blower is $1500 new and $600 rebuilt. Mini said 6 hours labor.
Expensive part. A car should not need this part replaced.
Old Aug 9, 2010 | 07:07 AM
fishey72's Avatar
fishey72
It is mostly a result of poor serviceability design. The ports to add/change oil for the supercharger are hidden by the coupling of the water pump to the sc.
So if you want change the oil in the supercharger you basically have to remove the front of the car and remove the water pump.
Old Aug 9, 2010 | 07:09 AM
ninjamini's Avatar
ninjamini
That should just not be. BMW/Mini should do a better job in design.
Old Aug 9, 2010 | 07:13 AM
DAVESTER's Avatar
DAVESTER
Sorry guys. I'm referring to the fan motor inside the car and not the supercharger. It squeals when the fan is on.
Old Aug 9, 2010 | 07:17 AM
fishey72's Avatar
fishey72
Lot's of stuff in here.
https://www.northamericanmotoring.co...ater-pump.html
Old Aug 9, 2010 | 07:34 PM
healey67's Avatar
healey67
Not that bad of a job... you Dont have to take everything apart to get to it!!
Old Aug 10, 2010 | 10:04 AM
CrazyIvan's Avatar
CrazyIvan
Lol. Mine has been making the same noise for a while now. I can't believe the price they are trying to charge just for the fan motor it's crazy.
Old Dec 2, 2010 | 03:59 PM
mtgperson's Avatar
mtgperson
Blower motor noise only when cold
Hi everyone,
My R56 blower motor only make noise when it was cold outside, once the temperature warms up the noise disappeared. The noise only appears on low fan settings, when I turn up the fan speed the noise goes away. I did a search but cannot find anything related to temp and blower fan noise, any suggestions?
Thank you,
Sincerely,
mtgperson
Old Dec 2, 2010 | 04:17 PM
ZippyNH's Avatar
ZippyNH
Originally Posted by mtgperson
Hi everyone,
Thank you,
Sincerely,
mtgperson
Try the gen2 forums...most gen1 folks with '02-06' r50/r53 hard tops or the 07+08 cabrio's r52's know little about the gen2 cars unless they sold one to get a gen2!!
Old Dec 2, 2010 | 04:20 PM
mtgperson's Avatar
mtgperson
Thanks ZippyNH for the suggestions, I will repost under generation 2.
IQRaceworks
53
Jun 28, 2024 07:29 AM
NYMADMINI
Dec 14, 2016 02:33 PM
Scm68
Jan 27, 2016 12:33 PM
OutMotoring
Nov 16, 2015 07:04 AM
