replace water pump???
Old Aug 3, 2010 | 04:16 PM
ninjamini's Avatar
ninjamini
My 05 MCS needs a new super charger and I am wondering if I should replace the water pump. It was working fine and I am out of a job right now. But its only $220 more to get a new one.
When should I expect this pump to fail??? Should I replace.
Old Aug 3, 2010 | 04:51 PM
RobertJ's Avatar
RobertJ
Miles?
Old Aug 3, 2010 | 05:26 PM
ninjamini's Avatar
ninjamini
Almost 76,000 meant to put that.
Old Aug 3, 2010 | 08:54 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The labor to do it alone later is more than the part alone so I'd do with with the supercharger. That's part of the reason we keep them in stock.
http://www.waymotorworks.com/r53-water-pump.html
Old Aug 3, 2010 | 10:33 PM
MCSfanboy's Avatar
MCSfanboy
Agreed. Even if your water pump lasted another 30K (which it could), this is way too much work to go through later. Pay a little now, save big $$$ later.
Old Aug 3, 2010 | 10:48 PM
k-huevo's Avatar
k-huevo
Originally Posted by ninjamini
...should replace the water pump. It was working fine and I am out of a job right now....When should I expect this pump to fail???...
Look at the drive key; does it have chewed rubber bits around it?
Is there evidence of fluid around the weep hole?
Did it squeal upon start-up?
If the answer is no to all three questions, don't replace the pump for proactive reasoning alone. Failed water pumps do happen, but instances are rare, much less so than failed water pump drive gears on the SC.
Old Aug 3, 2010 | 11:36 PM
MiniKar's Avatar
MiniKar
I agree, since they are in there removing parts have them do it now instead of waiting for it to fail.
Take a look at what else may fail in the near future and do it now; put it on a charge card.
Old Aug 4, 2010 | 05:53 AM
ninjamini's Avatar
ninjamini
Does it change anyones opinion that as soon as I get back to work I will be geting a new mini and trading this one in?
Old Aug 4, 2010 | 09:03 AM
fishbone's Avatar
fishbone
I would say yes. In that case, leave the pump alone if it looks AOK on inspection.
Cereall
Sep 5, 2019 06:05 PM
KrisMiss
Jan 3, 2016 02:02 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
gmonde
Sep 8, 2015 06:37 AM
kwijmbo
Aug 5, 2015 09:00 PM
