Drivetrain what would be a good top mount engin damper..
Old Jul 19, 2010 | 04:22 PM
minikania's Avatar
minikania
i dont like the taxes speedworks.. anyone one ells with some good ideas
i have a r53 03....
Old Jul 19, 2010 | 04:25 PM
MINI33342's Avatar
MINI33342
Get the powerflex bushings for both top and bottom....cheaper and more effective.
Old Jul 19, 2010 | 04:47 PM
ACallahan's Avatar
ACallahan
+1 on this. Recently had top , bottom and gearbox , powerflex sent to me from Way. Good bit of vibration untill the bushings sit in some but very nice change smoothness of shifting.
Old Jul 19, 2010 | 05:29 PM
TBangin23's Avatar
TBangin23
So you'd recommend this over the tsw damper?
Old Jul 19, 2010 | 06:12 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I have a full set of polyurethane engine bushings, and after 35,000 miles they are loosing their effectiveness. Interior vibrations are nearly gone and shifting/throttle response is poorer. (than it was after installation, yet it's still better than stock.) I want solid mounts.
Old Jul 19, 2010 | 06:18 PM
TBangin23's Avatar
TBangin23
So what would everyone recommend?
Old Jul 19, 2010 | 07:33 PM
ijcwmc40's Avatar
ijcwmc40
i have a r53 03....
Were you thinking of an add-on like TSW (IMO a rattler and shaker? Take a look at the VIP engine stabilizer, IMO is far superior to other dampers I've seen and or experienced.
see it here www.vipcustomparts.com
Old Jul 19, 2010 | 07:42 PM
Daeus
I'd recommend the VIP one too....but it only fits 04+.
Old Jul 19, 2010 | 07:55 PM
TBangin23's Avatar
TBangin23
Well darnit.. That doesn't help me then! Lmao. I've got a '03. Anyone recommend any for that year?
Old Jul 19, 2010 | 09:54 PM
minikania's Avatar
minikania
something along those lines would be perfect... but mine is a 03...
Old Jul 20, 2010 | 02:54 PM
ijcwmc40's Avatar
ijcwmc40
sorry, did you give them a call, I believe it will fit cars produced late '03.
Old Jul 20, 2010 | 04:57 PM
MINI33342's Avatar
MINI33342
Go for the powerflex bushings. http://www.outmotoring.com/mini-coop..._bushings.html
Over 25k miles with no problems. If they do go "soft" they are easier and cheaper to replace.
The VIP product is only applicable to the 11/03 and after builds. It is used in addition to the later "can" type of engine mount (which did away with the stabilizer that the earlier cars had)
Old Jul 21, 2010 | 09:04 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If you don't like the TSW, definetly go for the Powerflex bushings. We have a couple sets for the Engine that will do the whole engine.
http://www.waymotorworks.com/powerfl...shing-set.html
If you want something harder we offer a race set of inserts for the engine and gearbox.
And if you want harder than that we offer the BSH lower mount.
Old Jul 21, 2010 | 09:08 PM
TBangin23's Avatar
TBangin23
do the Powerflex bushing last? like, more than 60,000 miles or am i gonna be replacing these?
Old Jul 21, 2010 | 09:26 PM
MINI33342's Avatar
MINI33342
Way, you might want to be a bit more specific on the model years for your different sets. The earlier years 5 piece are good for up to the 11/03 builds (04 model yr).
Old Jul 21, 2010 | 09:27 PM
MINI33342's Avatar
MINI33342
Don't know why not.......
Old Jul 21, 2010 | 09:30 PM
WayMotorWorks
Vendor
Yes I'm workin on it, just real busy with everything going on. Still need to get the pics up too.
Old Jul 22, 2010 | 04:48 PM
MINI33342's Avatar
MINI33342
Old Jul 25, 2010 | 07:09 PM
minikania's Avatar
minikania
i have the bsh lower mount... already is that enuff? i just thought i would need somthing up top to balance everything out ?
Old Jul 25, 2010 | 07:38 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
With the BSH lower, trying to stiffen the top up with an add on like the VIP or TSW dampers isnt realy going to make "MUCH" differance for a DD. If you really want to stiffen the top up more, I would recomend the TSW upper engine mount, not the engine damper. it is a solid urithane mount that is a total replacement for the "can" mount on '05+ cars and they have a version for the '02-'04 style. It is now avalible through WAY, check it out on his site or give him a call, he will set you straight.
09R56
Nov 16, 2022 10:49 AM
minimofo
Dec 26, 2015 11:45 AM
silence2-38554
Nov 12, 2015 09:39 AM
bleonard1401
Aug 4, 2015 09:39 PM
