Navigation & Audio R56: No audio from any of the audio sources all of a sudden.
Old Jul 18, 2010 | 07:02 PM
STLMINI's Avatar
STLMINI
All of a sudden today the audio in my 2007 R56 cut out. It was working earlier today.
Nothing from any of the audio sources. No satellite radio, no ipod, no audio in, no navigation, no terrestrial radio. Not even voice command.
I have the Navigation system and "premium" audio system.
Any ideas? Could it be a fuse?
Thanks,
Mike
Old Jul 18, 2010 | 07:10 PM
Yeah.ThatsRice.'s Avatar
Yeah.ThatsRice.
I ran into a similar problem. But I'm assuming you tried to restart the car to see if it reset itself. If the car is not receiving power from the battery, the audio will not work. I'm guessing you have already started your car (thus the battery is connected), but just in case, check if either of the terminals are loose at all.
Old Jul 18, 2010 | 07:20 PM
STLMINI's Avatar
STLMINI
Yeah, car started just fine. I shut it down and started it again and nothing different. Everything works fine, just no audio. Wait, no, I take that back. When I push a button to try to turn the audio on and off or try to change audio sources, there's a delay.
Wierd.
Old Jul 19, 2010 | 10:55 AM
Yeah.ThatsRice.
I would
Check the fuses. On the r55 it's on the passenger side right next to the door behind a plastic panel. On the back side of the panel there is a list of each fuse and the function of the component being fused. If you don't have a meter to check, just pull out a fuse that you're not using at the moment (one of the same fuses, the list also states what kind of fuse it is) and plug it in to see if you get audio. If that still doesn't work, it's time to go to the dealer.
Old Jul 22, 2010 | 10:17 AM
TECENG's Avatar
TECENG
This happened to me recently right after I replaced my speakers. I though I screwed something up until I realized that I had NO sound from ANY source.
I pulled over, shut down the engine, then restarted...no change. So I drove a few miles and tried it again, then everything worked fine. Hasn't happened since.
Old Jul 22, 2010 | 02:43 PM
miniSQ's Avatar
miniSQ
Happened to me too....i thought i did something wrong as well. So i went looking for fuses that might have blown. I ended up pulling about 15 fuses...they were all fine...but somehow the act of pulling them and putting them back in made it go away. Gremilins????
Old Jul 22, 2010 | 05:35 PM
MotorMouth's Avatar
MotorMouth
That is called "reseating". For a troubleshooter it comes soon after "rebooting".
Old Jul 23, 2010 | 06:36 AM
moondawg14's Avatar
moondawg14
LOL.
Some amps will protect themselves by cutting out audio if there is a short in the speaker wires. If you're handy with an ohmmeter you could ohm-out the speaker connections to check for a short.
Old Aug 5, 2010 | 10:22 AM
STLMINI's Avatar
STLMINI
The next day everything was fine and has been fine ever since. I go in later this month for my final check before maintenance expires. I'll let them know.
Wierdness.
F55MidnightBlackCooperS
Navigation and Audio
37
Apr 14, 2016 12:55 PM
Filmy
Sep 7, 2015 08:27 PM
Sep 4, 2015 02:12 PM
Minnie.the.Moocher
Sep 2, 2015 01:43 PM
jeffbeckhudd
Aug 29, 2015 09:11 PM
