What instrument/product to use for precise tire pressure rea
Old Dec 7, 2003 | 07:22 PM
MiniPoo's Avatar
MiniPoo
I need a way to precisely monitor my tire pressure. My tires are Kumho Escta MX. I just figured out that gas station's AIR supply does not give correct readouts. I thought I was running 36/38 front and rear, but as I checked at a different location, the pressures were off. I see a lot of tire monitors for sale at places like Target and the like, but are they any good? Any recommendations? Oh, and is running 36/38 a little high, because the car seems to skate over imperfections in the roads. Not as much traction as I would like. Maybe I should lower the pressure a little? And sorry if this has been posted before. Thanks.
Old Dec 7, 2003 | 08:28 PM
tsprayfhs's Avatar
tsprayfhs
Most digital air guages have enough percission (sp), in that they will give you consistantly the same reading. Not 35psi and a min. later 38psi. That is really the important thing. The only way to know if your guage is accurate is to have it certified read $$. As long as it is consistant and it is the only guage you use you are OK. As i have always said, "A man with a watch knows what time it is. A man with two watches is never quite sure." If you are skating, drop the pressure.
Motor on
Old Dec 7, 2003 | 08:30 PM
tontobird's Avatar
tontobird
This is what I have, I've been surprised and satisfied with it's accuracy: http://www.brookstone.com/shop/produ...rch_words=tire pressure gauge
You can probably get one that's less expensive from another source, I get a discount at Brookstone.
Good luck!
_________________
I'm the boss, not you!
Get over here!
Gimme a kiss!
Old Dec 7, 2003 | 09:15 PM
forrest's Avatar
forrest
I've had little luck with digital gauges. Take 5 reads, and you get 5 different numbers.
The best luck I've had is a good mechanical ol' Meiser AccuGauge. They're made in Chicago.
zgokart's Avatar
zgokart
It seems to have some nice features, e.g., holds last reading and has a bleed valve. It's probably the bourdon (no, not bourbon) type gage, which is quite reliable and of which I keep two, one in each car.
Old Dec 7, 2003 | 11:09 PM
kenchan's Avatar
kenchan
i just use a cheepo mechanical pen type guage... no problems for me. :smile:
works great. and it does have consistent readings.
Old Dec 8, 2003 | 07:04 AM
FWD-MX5's Avatar
FWD-MX5
I use THIS from OG Racing. The price is reasonable and you can bleed air whil the gauge is still on the stem.
Old Dec 10, 2003 | 04:05 PM
Alex@tirerack's Avatar
Alex@tirerack
In car pressure monitors By SmartTire
but use this display to see pressure and temperature at each corner
or super acurrate air guages by Accutire
Alex
_________________
Alex ext 294
800 522 8473
Tire & Wheel forum moderator
www.tirerack.com
alex@tirerack.com
Old Dec 10, 2003 | 05:09 PM
JFEINSTEIN's Avatar
JFEINSTEIN
Accutire gauge from Tirerack was reasonable and works great.
Old Dec 10, 2003 | 06:26 PM
apexer's Avatar
apexer
I have the Accutire guage and like it. Only down side is it doesn't have a bleed function so you have to let a little air out at a time by pressing the guage part way on the valve to bleed off pressure.
Old Dec 11, 2003 | 06:25 AM
early_apex
i got a digital gauge from BMW that i've been very happy with. i've seen very similar gauges elsewhere for a few bucks less, but it's worth it even for the $30-40 bmw charges. i got mine a a BMW bike shop, but the car dealer can probably get the same part.
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
