R52 putting my mini cooper S in time need help
Old Jul 9, 2010 | 06:15 PM
jparker7's Avatar
jparker7
alright when I replaced the head gasket on myh aunts mini i marked the chain and the cam sproket but the marker wore off during the process. I think i got the timing off a tooth or two. the car runs and drives but has a miss in the upper rpms and seems down on power. when i put the timing triangle at 12 o-clock the number 1 piston isnt at Top dead center. if i want the timing mark to be at 12 oclock at tdc i would need to move the cam sproket about 3 teeth towards the fire wall. im not even sure if the arrow should be strait up at tdc but from my experience on other cars it should be, but I dont know since the mini is the worst car ive ever worked on. please please help or tell me what to do. Should i put the engine at TDC then make ther cam sproket be at 12 oclock
Old Jul 11, 2010 | 09:32 AM
jparker7's Avatar
jparker7
does anyone here work on their own cars
Old Jul 11, 2010 | 11:10 AM
PDWebb's Avatar
PDWebb
You might have more luck with a thread in another section. Sorry I can't help, I keep the engine internals to the pros.
Old Jul 11, 2010 | 03:25 PM
jparker7's Avatar
jparker7
not sure what section that would be. you would think at least one person on here would know how to put it in time.
Old Jul 12, 2010 | 11:06 AM
kenatminimania's Avatar
kenatminimania
On the cam sprocket, align the angular timing mark to the center of the 'single' copper colored timing chain link.
On the crank sprocket, align the two timing marks on the gear to the two side-by-side copper colored chain links (centered).
ken
TREX
Nov 2, 2019 07:31 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
