R50/53 Downshift, 7200rpm. Whoops!
Old Jul 3, 2010 | 11:53 AM
fixedcontext's Avatar
fixedcontext
Was driving late last night, angrily tried to overtake someone. Did an overly aggressive super sloopy downshift and ended up 2 gears down, obviously meant for 1. Engine didn't blow up or anything, drove the speed limit home and let it idle for a few moments..perfectly smooth, everything seems fine. Will there be any lasting damage from my moment of stupidity? As I said, the engine seems perfectly smooth, no ill noises, etc...
Old Jul 3, 2010 | 02:30 PM
CRoth's Avatar
CRoth
I think we've all done that by mistake at one point or another. If your engine is still running smoothly now, I'm sure you're fine.
Old Jul 3, 2010 | 03:25 PM
Achilless's Avatar
Achilless
Happens to everyone, your okay!
Old Jul 3, 2010 | 09:19 PM
Latka's Avatar
Latka
If you didn't throw a code right away my guess is that you're fine. My SWAG would be that as long as you didn't zing it over 8k you'd be ok.
Old Jul 4, 2010 | 10:13 AM
Crashton's Avatar
Crashton
Turn on some nice tunes to chill to while motoring along. Life's to short to get angry with folks in your way. I do understand your anger though.
If you hurt your car it would have happened then. It drives OK so all is well.
Old Jul 4, 2010 | 11:32 AM
MINI33342's Avatar
MINI33342
7200 rpm is not out of the safe range so all should be good.
Old Jul 6, 2010 | 02:12 PM
Keyser_Soze's Avatar
Keyser_Soze
Good thing you weren't driving American iron... I had a friend do that in an older Dodge Challenger... When the engine over-revved began singing like a soprano, it collapsed all the hydraulic lifters... No bueno...
Old Jul 6, 2010 | 02:22 PM
Tater Tot's Avatar
Tater Tot
I've done that with the paddle shifters, alittle scary but no problems
Old Jul 7, 2010 | 07:57 AM
JumpingJackFlash's Avatar
JumpingJackFlash
Brief over-revving is usually fine. It's continuously peaking that becomes a problem. Only NASCAR or Formula One engines can take the continuous beating of really high RPMs.
Like Achilless said, everyone's done it at one point.
Old Jul 7, 2010 | 08:15 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Sounds like you got lucky.
Old Jul 7, 2010 | 08:22 AM
JimRoberts12's Avatar
JimRoberts12
i was under the impression the engine (especially the auto box) won't let you "over rev". i don't know how the manual box could stop you from doing it in downshifting though?
Old Jul 7, 2010 | 08:40 AM
cmt52663's Avatar
cmt52663
it can't
Old Jul 7, 2010 | 08:44 AM
JimRoberts12
if you're reving up though it can kill power delivery though right?
Old Jul 7, 2010 | 08:57 AM
JumpingJackFlash
A rev limiter does not "kill" the engine. It simply limits spark to the engine, causing it to hover at the maximum programmed RPM redline. You can commonly hear this when someone revs their sport bike to the max. Unless you are at a drag strip, killing the engine's power unexpectedly is dangerous and against NHTSA regulations.
Old Jul 7, 2010 | 07:47 PM
Ministrater's Avatar
Ministrater
That must be what I felt when my foot got away from me and I took it into the red the other day. I felt sooooo bad....poor mini.
Old Jul 8, 2010 | 01:27 PM
reelsmith.'s Avatar
reelsmith.
Some of us twice.
Old Jul 8, 2010 | 01:40 PM
pillar's Avatar
pillar
http://www.youtube.com/watch?v=gKs7k0vMMTI
at least this isnt you
Old Jul 10, 2010 | 12:27 AM
BensMini's Avatar
BensMini
With the red lne @6500 you are in no real danger at 7200, but I wouldn't do it regularly, at 8000 you might regret it, but I have hunch it will stay together until 8500, but don't ask me to prove it.
Old Jul 14, 2010 | 10:48 AM
ntmid8r's Avatar
ntmid8r
I'll admit to it happening to me also.
IT actually chirped the tires as it slowed so fast...poor tranny.
Not sure what RPM it bounced to, as I was looking around to see if anyone saw me do it.
NO problems with engine or tranny since.
Old Jul 14, 2010 | 12:33 PM
Mat J Monk's Avatar
Mat J Monk
Wow, i didn't think you could get the kind of compression braking in a MINI! Of course, I hadn't really tried that hard! I did screw up a few downshifts trying to play Mario Andretti but I don't think I exceeded 6100 RPM.
BTW , Great stripe and one sharp looking car!
Old Jul 14, 2010 | 02:04 PM
Onimun's Avatar
Onimun
In the S2000 world, they Call that Money Shifting.
Old Jul 17, 2010 | 06:20 AM
ellcapitan's Avatar
ellcapitan
Originally Posted by pillar
...OR THIS, as seen in this long and painful clip: http://www.youtube.com/view_play_lis...&v=UCc3SOcNGxY
Old Aug 8, 2010 | 06:56 PM
ellcapitan's Avatar
ellcapitan
The only car I ever overrevved was a Dodge Neon. I was passing someone in second gear and was so "into it", I forgot to shift. It did not effect the engine.
Old Aug 20, 2010 | 08:29 PM
Maugre's Avatar
Maugre
Just a good way to make sure the rings are properly seated, no harm, no foul. You'll be OK. By the by, life is too short, don't let incompetent drivers ruin your day, swear at them in your mind, and then let it go. Good luck.
Old Aug 20, 2010 | 08:50 PM
Wetworth's Avatar
Wetworth
I can't add any informed opinion about engine damage; just you're in a MINI, relax and enjoy
