R50/53 Slap Shift's slow switch from 1st to 2nd
I have an 02 R50 automatic with a slap shifter.
It shifts slowly from first to second gear alowing me to lose many rpms in the transition.
Anyone got a fix or trick to switch it up faster?
2nd, my R50 was traded in for this reason
And many others have had problems. So I'd go easy if you can.
Also, there are no "gears"....you should very seriously *NOT* be able to feel a shift in gears with your CVT.
And many others have had problems. So I'd go easy if you can.Also, there are no "gears"....you should very seriously *NOT* be able to feel a shift in gears with your CVT.
I think also what people are saying is that since it's a CVT there are no "gears" in the transmission per se - You say you have paddle shifters though right? If they are on the CVT then I've noticed that shifts do feel odd when manually shifting a CVT although you never really loose power which is nice. Never driven a MINI one though...
Colt45Magnus
Aug 12, 2015 06:43 AM
