R56 Door Locks
Old Jun 17, 2010 | 06:33 AM
Racehorsemac's Avatar
Racehorsemac
Door Locks
I have a 2010 MCS automatic. Shouldn't the doors lock automatically when I put it in gear?
Old Jun 17, 2010 | 07:23 AM
erickvonzipper's Avatar
erickvonzipper
Did you try driving 6/10ths of a mile to see if they lock?
Old Jun 17, 2010 | 07:26 AM
Racehorsemac
They don't, only if I hit the switch.
Old Jun 17, 2010 | 07:47 AM
5spoke's Avatar
5spoke
I believe you can set it. I just got my 2010 mcs and I thought I read something about it in the owners manual.
Old Jun 17, 2010 | 07:54 AM
Racehorsemac
Thanks, I'll check it out.
Old Jun 17, 2010 | 08:34 AM
anuppercasej's Avatar
anuppercasej
There's a couple different options you can set it for... It explains it in the manual. I can't remember how to do it off the top of my head...
Old Jun 18, 2010 | 10:17 PM
kyounger's Avatar
kyounger
The option, if set (I don't have the manual handy either) will lock the doors at 10 MPH. I don't think there was a choice for "in gear".
Keith
07 MCS, Laser Blue/White
Old Jun 19, 2010 | 08:43 AM
klricks's Avatar
klricks
It's in the (tach) settings (key with checkmark icon).
There are 2 settings
The 1st setting I can't figure out a purpose for? When set, if you unlock the doors with the key fob and then -never open any doors-, the doors will automatically lock again after about 3 min. If you open a door before the timeout then the auto locking is canceled until you unlock with the FOB again.
....I guess if you were walking away from your car and you pressed unlock when you meant to press lock?
The other setting as someone said will automatically lock the doors when you hit 10 mph.
Other options will flash the parking lights when you lock/unlock with the FOB and/or sound a chirp (only if you have the factory alarm).
Note that the lights will only flash once. If you are looking for your car in a parking garage then you would have to hit unlock then lock..... in order to have the lights flash multiple times.
Old Jun 19, 2010 | 08:50 AM
AustinS's Avatar
AustinS
My FOB will only work within 20-30 feet...usually close enough to see the car.
Old Jun 19, 2010 | 12:15 PM
klricks's Avatar
klricks
I am pretty sure my FOB works at 200' plus. I have the Comfort access FOB if that makes a difference?
Old Jun 19, 2010 | 02:55 PM
OaklandMini's Avatar
OaklandMini
Touch the FOB to your chin and you'll gain a ton of range.
It'll use your body as the antenna...seriously.
Old Jun 20, 2010 | 01:18 PM
Pez D. Spencer's Avatar
Pez D. Spencer
Touch it to your chin? Its already being touched by your hand.
HogWldFLTR
Sep 8, 2015 05:25 AM
Filmy
Sep 7, 2015 08:27 PM
Gen1Parts
Sep 7, 2015 03:50 PM
Ntety
Sep 2, 2015 08:39 PM
spackletooms
Sep 1, 2015 10:12 PM
