R50/53 hose clamp question
Old Jun 6, 2010 | 07:00 PM
freeskier's Avatar
freeskier
hose clamp question
im swapping my power assisted steering tank to an aluminum forge motorsports unit and i need to disconnect the lines running out the bottom of it but they are attached with strange hose clamps that im not sure how to disconnect. any help would really be great. thanks
Old Jun 6, 2010 | 08:13 PM
Agarwaen's Avatar
Agarwaen
There are two types of hose clamps on Coopers that i know of. The first is a simple squeeze type. It has 2 prongs that you have to squeeze together to loosen it.
The second you will need a small-medium size flat head to remove them. Basically just put it in the metal loop and twist. To close it use a pair of channel locks and just squeeze it back into place.
But I'd prefer just replacing them with normal screw type clamps.
I'm going to go take a look at My tank, will be back with you in a sec.
Hmm..... I dont know, try the screwdriver thing. My tank is full of fluid, so I don't want to try it.
Old Jun 7, 2010 | 02:39 PM
freeskier's Avatar
freeskier
any one else have any experience with these? im doing the install tomorro after work and i wanna have some idea of how to do it before its time. thanks guys
Old Jun 7, 2010 | 05:42 PM
minintrigue's Avatar
minintrigue
I think you're talking about the squeeze type. If i recall, you just squeeze them and they come apart, but I've never figured out how to reuse them. If that is indeed the case, I'd pick up some of the old style clamps to reinstall - good luck
Old Jun 7, 2010 | 05:57 PM
freeskier's Avatar
freeskier
i have some of the older ones ready to go on. the squeeze type are what hold the line in to the coolant overflow tank, these are different but they are coming off with tin snips anyways. thanks
Khai
Feb 6, 2017 09:24 AM
Kahnfucious
Aug 15, 2015 08:43 PM
ASRman
Aug 13, 2015 09:33 AM
bleonard1401
Aug 11, 2015 02:53 PM
bleonard1401
R60/R61 Stock Problems/Issues
Aug 10, 2015 02:15 PM
