Major problem regarding oil.
Old Apr 26, 2010 | 04:20 PM
Fatandre's Avatar
Fatandre
Ok. I changed the Oil like 12.000 km ago. I am going to change it the day after tomorrow. I open the hood. check the dipstick and no oil showing. My face: :scared::scared:
Is this normal or what? I put Castrol Edge 5w-30
I havent had any problems with the car. It runs smooth. Hope nothing is damaged.
Old Apr 26, 2010 | 05:21 PM
mini_macky's Avatar
mini_macky
did you check the oil with the engine hot or did you check it 1st thing in the morning?
Old Apr 26, 2010 | 05:24 PM
Fatandre's Avatar
Fatandre
both. There is also this thing. The pan is sweaty and it seams to be oil
Old Apr 26, 2010 | 07:03 PM
56 Blue's Avatar
56 Blue
I would expect any normal engine to consume a quart of oil every 3,000 miles or so. I think that is about 5,000 km.
If you fill it up and it runs fine, you may not have damaged anything, especially in a colder climate.
What about volcanic ash? I think that would be a bigger worry.
Old Apr 26, 2010 | 07:41 PM
hoonpv's Avatar
hoonpv
Seems like your oil pan gasket is busted and leaking oil. A common issue.
Old Apr 27, 2010 | 05:55 AM
Fatandre's Avatar
Fatandre
Yeah. Thank god nothing happened to my engine. Will put some new oil tomorrow. Jus added some now.
Old Apr 27, 2010 | 07:08 AM
BlimeyCabrio's Avatar
BlimeyCabrio
How much did you have to add to be "full" on the dipstick? if only a quart or even two, you're probably OK. Any more that 2 and I'd start to worry a bit more.
Old Apr 27, 2010 | 07:24 AM
ZippyNH's Avatar
ZippyNH
I bet you will remember to check your oil regularly in the future. The mini may be able to go many miles between complete oil changes, but it still requires regular replenshiment. If the oil light ( low preassure= oil starvation) never came on, you should be fine...perhaps the oil ran a bit hotter, or the remaining oil had to run a lot harder, meaning you might have a trivial amount of extra wear, but IMO no worries.
One tip...if you have euro castrol edge (considering your location you should), us market castrol edge does not meet mini/BMW oil specs.
Old Apr 27, 2010 | 07:41 AM
Fatandre's Avatar
Fatandre
Well, the car is a US spec and I used the euro Castrol. Is that bad. What should I then use?
Old Apr 27, 2010 | 07:55 AM
MINIdave's Avatar
MINIdave
No, you used the right stuff....you just need to check it more often and top it up from time to time, that's all......
Old Apr 27, 2010 | 08:00 AM
Fatandre's Avatar
Fatandre
I will do that. Also fount my gasket is probably leaking. Everything in oil under the car.
Old Apr 27, 2010 | 12:00 PM
ZippyNH's Avatar
ZippyNH
The oil you used is fine. Better than fine actually
I guess you found the reason your car is low on oil.
If it is the oilpan gasket...it is a common leak
Replacement is pretty involved, most likely more than a beggining do-it-yourselfer would want to do. Possible, but a pain by most accounts.
I am glad to hear you found the scource of your low oil situation...it sucks that it is a leak, but the bright side is that you are not likely burning oil.
cerenkov
Apr 24, 2018 07:47 AM
maniacalmorgan
38
Sep 29, 2015 04:56 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
danraabe
Aug 18, 2015 09:32 AM
Lex2008
Aug 16, 2015 08:33 PM
