H&R Street Coilovers Clunking
Old Apr 21, 2010 | 12:00 PM
banggoo's Avatar
banggoo
I just got my H&R Street Coilovers, H-Sport lower control arms, and Whiteline Swaybar installed all at once. Now I am getting a CLUNKING noise when I go over bumps at slow speeds. I get the clunk noise both front and rear.
Looking at some older threads here and other forums the top nut on my strut might not be torqued properly.
Does anyone know the proper torque setting for the H&R coilovers, or if the noise is coming from somewhere else?
The H&R nut looks a lot bigger than the stock nut.
Thanks in advance.
Old Apr 22, 2010 | 08:45 AM
Alex@tirerack's Avatar
Alex@tirerack
I checked with HR for you, they said all factory torque specs should be used!
Alex
Old Apr 22, 2010 | 12:23 PM
howsoonisnow1985's Avatar
howsoonisnow1985
Grease (silicon) the swaybar and control arms too, just to make sure it is not that.
Old Apr 22, 2010 | 01:38 PM
banggoo's Avatar
banggoo
Thank you, Alex. Where do I find stock torque settings for the suspension?
I assumed it was different because the nut on the H&R strut is larger than the stock strut.
Old Apr 22, 2010 | 02:53 PM
Alex@tirerack
I don't have a manual for Mini, sorry I can't tell ya. Anyone else here able to look up top shock mount torque?
Old Apr 22, 2010 | 03:50 PM
JohnnyVillan's Avatar
JohnnyVillan
Did you change your endlinks too or are you running the stock ones?
Old Apr 22, 2010 | 04:34 PM
banggoo's Avatar
banggoo
I'm running stock endlinks.
Old Apr 23, 2010 | 08:17 PM
JohnnyVillan
^^I'm on stock endlinks too and they bang around alot. Maybe just another thing to check, but it would probably only be the front knocking if it was the endlinks.
Old Apr 24, 2010 | 08:23 AM
Alex@tirerack
Have a look at the paint of the springs, if its missing in some places: you can use vynil tube sliced along its lenth and ziptied onto the spring. This has worked for spring clunk (where dead coils rub eachother) for me before.
Think vynil jacket... Endlinks sound more likley
Old Apr 24, 2010 | 11:35 AM
banggoo's Avatar
banggoo
I checked my endlinks again. The front endlinks came loose from the swaybar. I guess it wasn't torqued properly. I also tightened the rear lower strut mount to 103 lbs.
All of the noise is gone except for the raking I am doing with the air dam. I might have raise it a little. Weird thing is the passenger side springs settled lower than the driver side.
Thanks everybody.
RIchard Nguyen
Sep 14, 2016 11:43 AM
CooperSharp
Oct 12, 2015 09:21 AM
eMINI of the State
Oct 2, 2015 03:12 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
gnhovis
Sep 28, 2015 04:07 AM
