215/45/17 with 40mm offset
Old Apr 13, 2010 | 01:59 PM
jblow's Avatar
jblow
Would this set-up run a risk of rubbing on a lowered R53? Planning to go with Dunlop Direzza Star Specs.
Old Apr 13, 2010 | 02:05 PM
BlckJCWGhst's Avatar
BlckJCWGhst
No
Old Apr 13, 2010 | 03:28 PM
searocko's Avatar
searocko
I ran that size on 17x7.5 40mm offset wheels and it rubbed in the rear just a little until the plastic wore away. Those were Bridgestone RE-01R tires with TSW lowering springs.
Old Apr 13, 2010 | 04:13 PM
quikmni's Avatar
quikmni
Yes. Depends on how low, amount of rear negative camber, and wheel width.
I rubbed a little with 17x7" +38mm offset wheels, 215/40x17 tires, H&R springs, and -1.7 camber. Since you plan 45 series that adds a great chance of rubbing. However, the rub should be minor and the plastic wheel well liner and wheel arch can be trimmed to eliminate the rubbing.
Old Apr 13, 2010 | 05:28 PM
Dinan604's Avatar
Dinan604
I run 17x7.5" wheels with 215/45/17 Star Specs in the same offset as you (ET40). I'm on CROSS/JIC coilovers with roughly one finger gap with no rub. I run -2.0 camber in the front and -1.0 in the back.
Old Apr 13, 2010 | 06:13 PM
slinger688's Avatar
slinger688
BlckJCWGhst,
Where did you get that quote in your sig?
Old Apr 13, 2010 | 06:24 PM
veggivet's Avatar
veggivet
Looks like another satisfied ALTA customer.
Old Apr 13, 2010 | 07:31 PM
veggivet's Avatar
veggivet
Back on topic, I think it would depend on how much you are lowered. FWIW, I run the same size tire with a 38 offset but not lowered other than what the Koni FSD's do (about 1/4 inch), and I have no rubbing issues.
Old Apr 13, 2010 | 09:31 PM
rjtrout2000's Avatar
rjtrout2000
It will be fine! Enjoy!
Old Apr 14, 2010 | 01:55 AM
howsoonisnow1985's Avatar
howsoonisnow1985
Doesn't Dunlop Star Specs come in a better MINI size of 215/40-17???
Old Apr 14, 2010 | 04:19 AM
slinger688's Avatar
slinger688
Howsoon, I think the Z1 Star Specs do come in 215/40 17.
Old Apr 14, 2010 | 06:06 AM
Alex@tirerack's Avatar
Alex@tirerack
They sure do!
Alex
Old Apr 14, 2010 | 06:36 AM
jblow's Avatar
jblow
Originally Posted by Alex@tirerack
Is the load rating on the 215/40/17 Star Spec sufficient for the Mini application? If so, I'm inclined to go that route.
Old Apr 14, 2010 | 06:40 AM
gokaht's Avatar
gokaht
I'm on 215/45R17 Dunlop Direzza DZ101's on BBS RZ's (17"x7" ET37), R53 with H&R springs, and I rub in the rear at full compression (hard bumps, etc)
Looks like its just the plastic edge of the rear wheel arch, but it's still chewing up the shoulder/sidewall of the rear tires, so I'm getting the fenders rolled when I put on the CF hood in a week or two.
If I was stock height or on 205's, I'd be fine.
Old Apr 15, 2010 | 06:58 AM
Alex@tirerack
1074 will excede the GVAR for mini, just not as high in load as the stock tires. Watch where you put your wheels.
Alex
Old Apr 17, 2011 | 01:28 AM
11cooperS's Avatar
11cooperS
Star specs are on the smaller circumference end of the spectrum in each size from what I've read. I have and R56, and everyone told me that 215/45/17 wouldn't rub on NM Engineering springs. Guess what?
I'd definitely go 215/40. I just placed an order for 16" feathers and 205/50/16 because of the rough ride and rubbing... But like I said, I'm in an R56.
bahman
Aug 6, 2016 07:19 AM
schwac2
Jun 14, 2016 04:06 PM
Chibi2
May 19, 2016 03:46 PM
vbmike
Oct 15, 2015 04:32 AM
